MHB An almost elementary differentiation problem....
The discussion focuses on expressing the second derivative of the Eta function at x=4 in terms of the Zeta function at the same point. The Eta function is defined as an alternating series, while the Zeta function is a standard infinite series. Participants explore the relationship between these two functions, particularly how differentiation affects their values. The problem emphasizes the need for a clear mathematical connection between the derivatives of the Eta function and the Zeta function. Ultimately, the goal is to derive a formula that links these two important mathematical concepts.
DreamWeaver
Let $$\zeta(x)$$ be the Zeta function (where, for convenience, $$x$$ is assumed to be $$> 1$$).
$$\zeta(x) = \sum_{k=1}^{\infty}\frac{1}{k^x}$$Similarly, define the Eta function (alternating Zeta function) by the following series - where again, in this case, we assume $$x > 1$$:$$\eta(x) = \sum_{k=1}^{\infty}\frac{(-1)^{k+1}}{k^x}$$
Problem:Express the second derivative of the Eta function - at $$x=4$$ - in terms of the Zeta function (differentiated or otherwise), at $$x=4$$.
Mathematics news on Phys.org
Isn't it just a matter of applying the product rule on $ \displaystyle \displaystyle \eta(x) = \left(1-2^{1-x}\right) \zeta(x)$ twice?
Thanks for taking part, Prometheus! :D
More -->
Yes, you're absolutely correct. The idea of the problem was to, potentially, encourage people who're less familiar with the functional relation you cited to develop it for themselves, then differentiate it.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
