I An Alternative explanation for energy loss due to Eddy currents
Eddy currents lead to energy loss primarily through joule heating, as described in the first explanation. The second explanation highlights that energy is also lost due to the interaction between the magnet and the induced magnetic dipole from the eddy currents, requiring work to overcome the forces involved. Both explanations are valid but focus on different aspects of energy loss: one on material properties and the other on magnet-material interactions. The discussion suggests that these represent two distinct avenues of energy loss rather than being the same phenomenon. Ultimately, understanding both mechanisms is crucial for a comprehensive view of energy loss due to eddy currents.
phantomvommand
TL;DR Summary
I have 2 explanations for energy loss due to eddy currents, please let me know which (or both) are correct, and how they ultimately agree with each other.
Explanation 1:
Eddy currents induced, energy loss due to joule heating.
Explanation 2:
Eddy currents induced, induced magnetic dipole formed. Energy is lost as work has to be done to overcome the attractive/repulsive force due to the magnet and the induced magnetic dipole from the eddy currents. (The magnet is always moving in the opposite direction of the force)
Are both explanations correct?
How do they reconcile/agree with each other? They seem to focus on completely different aspects of eddy currents. Explanation 1 is entirely restricted to the material on which eddy currents form, while explanation 2 involves the interactions between the magnet and the material. Is it that there are 2 avenues through which energy is lost due to eddy current formation, or are these '2 avenues' actually the same thing?
I would say they are two different "avenues". For example, if you drop a magnet through a metal tube, eddy currents will be formed in the tube that will exert a retarding force on the magnet opposite to g. The power pumped into the system will be ##mgv##, the ohmic loss is a ##-I^2R## term and the magnetic retarding force loss is a ##-F_M v## term. Conservation of energy (per unit time) requires that ##mgv-I^2R-F_Mv=0.##
Likes phantomvommand
Only ohmic hearing results in energy loss. In the case of eddy currents in a lossless conductor (superconductor, e.g.), mechanical work is balanced by the energy stored in the magnetic field of the current distribution.
Likes vanhees71 and phantomvommand
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
