An Automobiles acceleration and speed
In summary, to calculate the time it takes for a car to accelerate from 83 km/h to 101 km/h with an acceleration of 1.6 m/s2, you first need to convert the velocities into m/s by dividing them by 3.6. Then, using the formula a = (v-u)/t (where a is acceleration, v is final velocity, u is initial velocity, and t is time), rearrange the formula to make t the subject. Plug in the known values and solve for t. The final answer is approximately 3.125 seconds.
swede5670
78
At highway speeds, a particular automobile is capable of an acceleration of about 1.6 m/s2. At this rate, how long does it take to accelerate from 83 km/h to 101 km/h?
a = Change in Velocity / Change in time
How do you use 1.6m/s^2 when you also have 83 km/h to 101 km/h?
I know that I need to subtract 83 from 101 (18 km/h). The car needs to increase its velocity by 18 km/h accelerating at 1.6 m/s. I don't know how to use the 1.6 m/s in the equation to show the total time
You need to convert the 18km/h into m/s.
[tex]18km/h = 18000m/h[/tex] (convert km into m by x1000)
[tex]18000m/h = 5m/s[/tex] (It travels 18000m/3600s so simply divide)
In short, to convert from km/h to m/s, just divide by 3.6
e.g. 36km/h = 10m/s
But usually with these types of questions, they are approached a little differently to develop the habit and avoid a lot of confusion later on with the more difficult questions (well that's what most of my peers do anyway)
Using the equation:
[tex]a=\frac{v-u}{t}[/tex] where: v=final velocity, u=initial velocity, t=time, a=acceleration.
Note: this is the same as your equation, change in time = time, change in velocity = the final velocity - the starting velocity (101km/h - 83km/h)
Now just rearrange the formula so you make time the subject (because you are trying to find the time)
Therefore, [tex]at=v-u[/tex] (multiply through by t)
[tex]t=\frac{v-u}{a}[/tex] (divide through by a)
Now you have rearranged the formula so that you can plug in all the data you do know, use the calculator and end up with your answer for time.
From here you need to be sure that you convert the final and initial velocity into m/s
[tex]101km/h=\frac{101}{3.6}m/s=28\frac{1}{18}m/s[/tex]
[tex]83km/h=\frac{83}{3.6}m/s=23\frac{1}{18}m/s[/tex]
Plugging into the formula: [tex]t=\frac{28\frac{1}{18}-23\frac{1}{18}}{1.6}[/tex]
Using the calculator: (note: should be easy to see the numerator = 5, saves time writing fractions into the calculator)
[tex]t=3\frac{1}{8} seconds[/tex]
Thanks for the help, this was really useful
Related to An Automobiles acceleration and speed
1. What is the difference between acceleration and speed?
Acceleration refers to the rate at which an object's velocity changes over time, while speed is the distance traveled per unit of time. In other words, acceleration measures how quickly the speed of an object is changing, while speed measures how fast the object is moving at a specific point in time.
2. How is acceleration measured in automobiles?
Acceleration in automobiles is typically measured in meters per second squared (m/s²) or miles per hour per second (mph/s). This is calculated by dividing the change in speed by the change in time.
3. What factors affect an automobile's acceleration?
There are several factors that can affect an automobile's acceleration, including the engine power, weight of the car, aerodynamics, and friction between the tires and the road. The type of transmission, gear ratio, and road conditions can also impact acceleration.
4. Can acceleration and speed be increased in an automobile?
Yes, there are various ways to increase acceleration and speed in an automobile. This can include optimizing the engine, reducing the car's weight, improving aerodynamics, and using performance-enhancing technologies such as turbochargers or superchargers.
5. How does an automobile's acceleration and speed impact fuel efficiency?
An automobile's acceleration and speed can greatly impact fuel efficiency. Generally, higher acceleration and speed require more fuel to maintain, resulting in lower fuel efficiency. To improve fuel efficiency, it is recommended to drive at a consistent speed and avoid sudden acceleration or braking.
