An electron enters a magnetic field
The discussion centers on solving a physics problem involving an electron entering a magnetic field. The original poster (OP) attempts to relate kinetic energy and centripetal force to derive equations for the radius of the electron's path. Responses indicate that the OP's approach is generally correct, but suggest showing more detailed workings to identify potential mistakes. Additionally, it is noted that finding velocity is unnecessary for the second part of the problem, as kinetic energy can be directly related to force and radius. Overall, the conversation emphasizes clarity in problem-solving steps and the relationships between physical concepts.
Dominic90
An electron, accelerated from rest by a potential difference ∆V, enters a magnetic field B, perpendicular to the lines of force. The electron therefore travels a circular trajectory of radius r. If ∆V is doubled and B halved, what will be the radius R, as a function of r, of the new trajectory?
The same electron is now in uniform circular motion of radius 26.1 𝜇𝑚 subject to a field uniform magnetic. The magnetic force acting on it has an intensity of 1.60 ∙ 10^(−17)𝑁.
Calculate the kinetic energy of the electron.
K = (1/2) mv²
E = q ∆V
r = m v / (|q|B)
F = |q|vB
Centripetal force = mv²/r
Hi, I tried to solve this exercise but I'm not sure about the process.
First of all, I imposed that "K = E":
so that "v = √ ( (2q ∆V)/m))"
then I replaced in "r = m v / (| q |B)", v with "√ ( (2q ∆V)/m))", and found out that R = (2√(2)) r.
Then for the second point,
I imposed Lorenz Force Law = Centripetal force and isolated v.
Then I substituted v in K
and obtained that "K= (1/2 ) F r".
Is this correct?
Likes Delta2 and hutchphd
Title: “An electron enters a magnetic field”
Ah, I was expecting a joke.
Likes 2milehi, Dominic90 and hmmm27
Except the joke would have to start something like "an electron, a neutrino, and a muon enter a magnetic Field..."
By the way the OP looks good to me.
Likes Steve4Physics and Dominic90
... then charged out again. It wasn't very attractive and kept giving it the runaround.
Likes Steve4Physics, Dominic90 and hutchphd
@Dominic90, I also agree with your answers. (And sorry about Post #2.)
As a general point, maybe it helps to show the working, rather than just describe the 'process'. (This makes it easier to identify the source of mistakes, if there are any.)
For the second question, there is no need find v first. Note that K = ½mv² and F = mv²/r. You can easily combine these to show that K = ½Fr.
Likes Dominic90 and hutchphd
I was expecting something about grammar since this isn't my first language, but then I cracked up xD
Likes Steve4Physics
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
