An excercise in graviation by misner, thorne and wheeler
  • Thread starter zasdzcc
  • Tags
    Wheeler
In summary, the problem requires defining the direction unit vector $$\hat{n}$$ and the velocity vector $$\vec{\beta}$$ in the frame of the rocket with velocity $$\vec{\beta}$$, and showing that the Poynting vector vanishes in this frame. Using Lorentz transformations, the fields in the rocket frame can be expressed in terms of the fields in the rest frame, with the Lorentz factor ##\sqrt{1-\beta^2}##. However, it is not possible to assume that the cross product of the perpendicular components of the fields in the rocket frame will cancel out, as this must be shown. Further steps would be needed to complete the solution.
zasdzcc
My question is on problem 4.1 of Gravitation. In a generic case of electric field and magnetic field(i.e not $$E=0$$ or $$B=0$$ or $$E$$ and $$B$$ perpendicular), define the direction $$\hat{n}$$ unit vector ,
$$\hat{n}\tanh (2\alpha)=\frac{2\vec{E}\times\vec{B}}{\vec{E}^{2}+\vec{B}^2}$$
and $$\vec{\beta}=\tanh(\alpha)\hat{n}$$
is the velocity vector.
Show in the frame of the rocket with velocity $$\vec{\beta}$$, the Poynting vector vanishes.
\begin{align}
\bar{\vec{E_{\parallel}}}&=\vec{E_{\parallel}}, \\
\bar{\vec{E_{\perp}}}&=\frac{\vec{E_{\perp}}+\vec{\beta}\times\vec{B_{\perp}}}{\sqrt{1-\beta^{2}}},\\
\bar{\vec{B_{\parallel}}}&=\vec{B_{\parallel}}, \\
\bar{\vec{B_{\perp}}}&=\frac{\vec{B_{\perp}}-\vec{\beta}\times\vec{E_{\perp}}}{\sqrt{1-\beta^{2}}}.
\end{align}
Note $$\beta\times X_{\perp}=\beta\times X$$
I tried the following but I am stuck at the cancellation.
Let the $$\bar{\vec{E}}$$ and $$\bar{\vec{B}}$$ be the field in the rocket frame and the field without bars be the field of the rest frame. direction parallel along the velocity of rocket is denoted as subscript $$\parallel$$ and direction perpendicular to velocity of rocket direction is denoted by $$\perp$$ as the subscript.
By lorentz transformation.
\begin{align}
\end{align}
Note $\beta\times X_{\perp}$=$\beta\times X$
In barred frame,
\begin{align}
\bar{\vec{E}}\times\bar{\vec{B}}
&=(\bar{\vec{E_{\perp}}}+\bar{\vec{E_{\parallel}}})\times(\bar{\vec{B_{\perp}}}+\bar{\vec{B_{\parallel}}})\\
&=\bar{\vec{E_{\perp}}}\times\bar{\vec{B_{\parallel}}}+\bar{\vec{E_{\parallel}}}\times\bar{\vec{B_{\perp}}}.
\end{align}
Plug in the lorentz transformation. One gets
$$\frac{\vec{E}\times\vec{B}-\vec{E}_{\parallel}\times(\vec{\beta}\times\vec{E})-\vec{B}_{\parallel}\times(\vec{\beta}\times\vec{B})}{\sqrt{1-\beta^{2}}}.$$
Now the last two terms looks generically like $$\vec{X_{\parallel}}\times(\vec{\beta}\times\vec{X})$$ simplifies to $$\vec{X_{\perp}}(\vec{X}\cdot\vec{\beta})$$.
However, I could not see the cancellation at this stage any where. Did I do something wrong?
Hello, zasdzcc.
How are ##\vec{E}## and ##\vec{B}## (in the original frame) oriented relative to the boost direction ##\vec{\beta}##? What does that tell you about ##\vec{E}_{\parallel}## and ##\vec{B}_{\parallel}##?
zasdzcc said:
In barred frame,
\begin{align}
&=\bar{\vec{E_{\perp}}}\times\bar{\vec{B_{\parallel}}}+ \bar{\vec{E_{\parallel}}}\times\bar{\vec{B_{\perp}}}.
\end{align}
EDIT: You can't assume that ##\bar{\vec{E_{\perp}}} \times \bar{\vec{B_{\perp}}} = 0##. That's something you need to show.
Likes 1 person
Related to An excercise in graviation by misner, thorne and wheeler
What is "An Exercise in Gravitation" by Misner, Thorne, and Wheeler?
"An Exercise in Gravitation" is a textbook written by Charles W. Misner, Kip S. Thorne, and John Archibald Wheeler. It was first published in 1973 and provides a comprehensive overview of the theory of general relativity and its applications.
Who are the authors of "An Exercise in Gravitation"?
The authors of "An Exercise in Gravitation" are Charles W. Misner, Kip S. Thorne, and John Archibald Wheeler. All three are renowned physicists and have made significant contributions to the field of general relativity.
What topics are covered in "An Exercise in Gravitation"?
"An Exercise in Gravitation" covers a wide range of topics related to general relativity, including the basics of curved spacetime, gravitational waves, black holes, and cosmology. It also includes exercises and problems for readers to practice and apply their understanding of the concepts presented.
Is "An Exercise in Gravitation" suitable for beginners?
No, "An Exercise in Gravitation" is not suitable for beginners. It is a highly technical and mathematical textbook intended for advanced students and researchers in the field of physics.
What makes "An Exercise in Gravitation" a valuable resource for scientists?
"An Exercise in Gravitation" is considered a classic in the field of general relativity and is highly regarded for its in-depth and rigorous treatment of the subject. It also includes many exercises and problems that allow readers to apply their knowledge and improve their understanding of the theory. Additionally, the authors' expertise and contributions to the field make this book a valuable resource for scientists in the field of general relativity.
