An experiment to measure the Speed of Light
In summary,The speaker wants to make an experiment to measure the speed of light. They plan to have a light source in the dark and two sensors that will detect when light is detected. The experiment will stop when the time it takes for the two sensors to detect the light pulse is recorded. They have no idea if this is a good idea, or if it would work, but they want to get opinions.
SapientiaPT
So, pretty much I want to make an experiment in order to get the speed of light.
What I plan to do is to have a lantern in the dark(initially off) perpendicular to a wall, two sensors(one closest to the lantern and the other closest to the wall), then turn on the light making sensor 1 go off as soon as it detects light and starting a stopwatch and sensor 2 stopping the same stopwatch, therefore getting the time it took from sensor 1 to sensor 2, and finally dividing distance betweens sensor 1 and 2 by the time the stopwatch registered. I have NO idea if this is even a good idea, or if it would work. Would like to get some opinions on this, and if you think this is possible, let me know if you know of a way to make the sensor/stopwatch system work.
Thanks in advance.
Science news on Phys.org
If you can get your fingers and the stopwatch mechanism to both operate at several tens of thousands of times faster than is physically possible, then it might work.
EDIT: actually, thinking about it just a bit more, I think my estimate was probably considerably too optimistic.
Likes SapientiaPT
Yeah, that was what I was afraid of... that they wouldn't be as fast as needed... So I guess that's that... Thank you anyway.
Welcome to the PF. :smile:
Except, you can think about versions of your experiment that you may be able to do with some not-too-expensive equipment someday soon.
First, Have you tried measuring the speed of sound with a similar technique? stand a few hundred feet from a large flat surface (like the side of a warehouse, clap you hands together hard once, and notice the delay of the echo. You can experiment with timing that delay (have somebody else do it for you if you do the clap), and changing your distance to the wall. Take about 10 measurements at each distance, and average them to get a better value. You can look at the distribution of values you get at each distance to see what the "error" is in your experimental setup, and you can think of ways to improve the accuracy. (Hint, there may be a way to use a cellphone to improve on this basic echo setup...) :smile:
And for starting to measure the speed of light, you just need light sensors that respond quickly, and a way to measure the difference in time for the light pulse reaching the two sensors. Light travels about 1 foot every nanosecond, so if you can separate your two sensors by several hundred feet, you can start to measure the time delay with a pretty basic oscilloscope (you can see if your local school electronics lab has such an oscilloscope that you can use, for example). The light sensors have to have a fast response time, but you could use pre-packaged fiberoptic receiver modules, for example.
Stay curious and keep asking questions. That's a great way to learn! :smile:
EDIT/ADD -- And keep in mind that the cables that you connect to your two sensors need to be the same length (from your two sensors back to your oscilloscope or other time measuring device). Can you say why that is important?
Likes SapientiaPT and phinds
Yeah, those are interesting ways. Thanks :smile:
Likes berkeman
Why don't you actually try to calculate the time interval you'd be measuring? It's easy to do and will tell you immediately if a particular stopwatch is precise enough (though there are additional practical concerns...).
You might want to google for “cogged wheel light speed” to see how Fizeau did these measurements in the middle of the 19th century. It’s an an ingenious technique for getting good speed measurements without hyper-accurate clocks.
Likes SapientiaPT, Ibix, Delta2 and 1 other person
Yeah, that's also an interesting idea. Might consider it.
Unless you do not believe in the relationship v = fλ, why not try to measure the wavelength of several different frequencies of light? Then plot f versus 1/λ, and the slope of your straight-line fit is the speed of light!
Zz.
Likes SapientiaPT, sandy stone and Nugatory
According to Google, this general approach has been implemented for a specific frequency using microwave ovens and chocolate bars.
Likes SapientiaPT
Except that in that case, it was done only for ONE particular frequency.
Zz.
Likes jbriggs444 and SapientiaPT
Cheese slices are more effective than chocolate wrt area coverage.
But not as fun in the after-party unless nachos.
  • Haha
Likes jedishrfu, berkeman, russ_watters and 1 other person
Maybe @DaveC426913 suffering from Broken Heart Syndrome:
https://www.wkyt.com/content/news/Woman-diagnosed-with-broken-heart-syndrome-mistook-wasabi-for-avocado-561263911.html
LOL, okay folks, back on topic please... 😉
Likes SapientiaPT
Related to An experiment to measure the Speed of Light
1. How is the speed of light measured in an experiment?
In an experiment to measure the speed of light, a beam of light is directed through a vacuum tube with a known distance. The time taken for the beam of light to travel from one end of the tube to the other is measured using precise instruments. This time, along with the distance, is used to calculate the speed of light.
2. What is the significance of measuring the speed of light?
The speed of light is a fundamental constant in physics and plays a crucial role in many theories and equations. By accurately measuring the speed of light, we can better understand the nature of light and its interactions with matter. It also helps in the development of technologies such as telecommunications and space exploration.
3. How accurate are the measurements of the speed of light in experiments?
With advancements in technology, the accuracy of measuring the speed of light has significantly improved. Currently, the most accurate measurement of the speed of light is 299,792,458 meters per second, with an uncertainty of only 0.000,000,000,008 meters per second.
4. What are the different methods used to measure the speed of light in experiments?
There are several methods used to measure the speed of light, including the Fizeau-Foucault method, the Michelson method, and the cavity resonance method. Each method has its own advantages and limitations, and scientists often use a combination of methods to obtain the most accurate results.
5. Has the speed of light always been measured to be the same value?
Yes, the speed of light has been measured to be the same value since the 17th century. However, with advancements in technology and more accurate measurements, the value has been refined over time. The currently accepted value of the speed of light is 299,792,458 meters per second, which is the same as the value measured hundreds of years ago.
  • Optics
  • Materials and Chemical Engineering
  • Mechanical Engineering
