An extremely basic question on MCNP
  • Thread starter Thread starter Takvorian
    Mcnp
The discussion revolves around calculating the dose rate from an MCNP simulation involving a Co-60 source within a spherical air volume. The user obtained a tally result of 1.4657E-15 mSv/h/particle and sought guidance on how to convert this to a dose rate for a source activity of 1E+6 Bq. A method was shared that involves calculating the number of emitted photons and using conversion factors from ICRP 74 to derive the dose equivalent rate. The final calculation provided a dose rate of 3.44E-7 Sv/h. The user expressed gratitude for the clarification received.
Takvorian
TL;DR Summary
How to calculate the gamma dose rate from MCNP results ?
Hi there,
I have a very simple question about MCNP (6.2 to be precise) ... maybe someone here might enlighten me ...
Based on the (more than simple) MCNP input file below, which describes a sphere with R=200cm, filled with air and a point source in the center. There's a single ring tally on the X axis in a distance of 100 cm from the source, which should give the results in mSv/h/particle. The source is Co-60 with its 3 gamma photons defined.
When I run that file, the tally F15 gives me a value of 1.4657E-15 mSv/h/particle (error is 0.0008).
Question: How do I calculate the correct dose rate for a source with i.e. 1E+6 Bq from that tally result ?
Greetings and may that not too boring a question ... but that topic seems to be a bit neglected in the manuals and lectures ... :(
Takvorian
[CODE title="MCNP input"]MCNPX Visual Editor Version X_25
c Created on: Wednesday, February 23, 2022 at 19:58
1 304 -0.001205 -1 imp:p=1
2 0 1 imp:p=0
c Welt
1 so 200 $Welt
mode p
m304 6000 -0.000124 $Air (Dry, Near Sea Level) Density: -0.001205
7014 -0.7525 7015 -0.0027668 8016 -0.23123
8017 -8.7866e-005 18036 -4.2793e-005 18038 -8.0671e-006
18040 -0.012776
sdef pos=0 0 0 ERG=D1
c
c source energies (Co-60)
si1 L 0.6938 1.1732 1.3325
sp1 D 1.6312e-4 1 1
c
f15x:p 100 1 -0.125
df15 IU 2 ic 10
stop F15 0.0005 [/CODE]
Hi,
for my part to calculate dose equivalent rate, I use a function response (DE/DF).
The “de” card contains discrete energies and the “df” card provides the values of the conversion
factors from ICRP 74.
For example for photons in terms of H*(10) :
DE15 .01 .015 .02 .03 .04 .05 .06 .08 .1 .15 .2 .3 .4 .5 .6 &
.8 1 1.5 2 3 4 5 6 8 10
DF15 0.061 .83 1.05 .81 .64 .55 .51 .53 .61 .89 1.2 1.8 2.38 2.93 3.44 &
4.38 5.2 6.9 8.6 11.1 13.4 15.5 17.6 21.6 25.6
Your results are in pSv for one particle.
So for A=1E6 Bq you must calculate the number of photons :
N=1E6*( 1.6312e-4 + 1+ 1)=2E6 gamma/s
MCNP gives F5=4.7807E-05 (the unit is pSv per photon)
So H*(10)=4.7807E-05*1e-12*2E6*3600= 3.44E-7 Sv/h
I insert input and output files
This is well described in this book :
https://www.researchgate.net/publication/355444601_Radiation_problems_from_analytical_to_monte-carlo_solutions
Likes Astronuc, Takvorian and berkeman
Thanks - that resolved my question.
