Buzz Bloom
- 467
- TL;DR Summary
- From other thread discussions (see the body for examples) , a consensus seems to be that it is not possible to know whether or not the universe is flat. This thread is seeking some expert understanding regarding the reasonableness of calculating a plausible probability that the universe is flat.
References
Suppose the Friedmann equation is used to analyze two models.
The following is just a example of a concept about making such a comparison. I do not think it is a correct method. It is intended only as an illustration of a result of a method allowing for a reasonable comparison between F1 and F2.
Suppose we define G as follows.
The result means that P2 is the probability that the universe is flat. P1 is the probability that the universe is not flat.
Reference 2 makes a specific assumption that the universe is not flat. Based on this assumption, approximately the probability the universe is finite is 70%, and the probability the universe is infinite is 30%. Base on the concept that P1 and P2 can be calculated, using these probabilities gives the following results.
(1) H0 and all four Ωs can in principle have various values.
(2) H0 and three of the four Ωs can in principle have various values,
but Ωk = 0.
For both of these two models, a best fit to the same database of values is calculated., say F1 and F2. I am not sure what the proper method would be for calculating a fit value, but the best fit is the smallest value, and the best bit includes the specific variable values that produced this best fit. For the purpose of this discussion, I will assume the method is the following for the fit value.F = Σi,j (Vdb,i,j-Vm,i,j)2
i is an index over the database sets of variable values.
j is an index for the variables within each set of variables
Vdb is a variable in the database
Vm is a corresponding variable whose values are calculated using the
Friedmann equation.
Since F1 includes the results of one more Friedmann equation variable than F2, I would expect thatF1 < F2.
If F2-F1 is small compared with F1, then I think it would be likely that F2 should be considered to be a better fit than F1. I do not know the math for quantifying this, but this does seem to me to be reasonable. There should be a mathematical way to compare F1 and F2 so that an adjustment can be made for the difference in the number of variables.The following is just a example of a concept about making such a comparison. I do not think it is a correct method. It is intended only as an illustration of a result of a method allowing for a reasonable comparison between F1 and F2.
G = F1/2 / N,
where N is the number of model variables. ThereforeG1 = F11/2 / 5, and
G2 = F21/2 / 4.
Since the only difference is that F1 has a range of values for Ωk, but F2 has Ωk=0. I suggest that P1 is the probability that G1 is correct, and P2 is he probability that G2 is correct. I calculate as follows:P1 = G1/(G1+G2)
P2 = G2/(G1+G2)
P1 + P2 = 1
The probability that the universe is infinite and flat is P2.
The probability that the universe if a finite 3D hyper-sphere is P1 x 0.7.
The probability that the universe is is an infinite 3D hyperbolic shape is P1 x 0.3.
