An idea for integration that has been bugging me.
In summary: So you would need a substitution like so:u=f(x) so du = f'(x)dx and it would reduce to being:\int g(u)duBut it would be painful to find the inverse function of f(x) to get u in terms of x.In summary, the conversation was about the possibility of using substitution to remove ln(f(x)) from an integral and leave us with a simpler integral. However, it was determined that this is not a feasible method and would only work for specific functions where f(x) is proportional to f'(x)/f(x). The conversation also touched on the potential of a universal one-step method of integration, but it was concluded that
kts123
72
I've only recently started teaching myself Calculus, so you'll have to forgive me if I'm trying to do something silly or impossible. This has been bugging me for a few days, so I figured it's high time I ask someone.
Since we can write [tex]\int_{a}^b f(x)[/tex] as [tex]\int_{a}^b\ e^\ln(f(x))[/tex] would it be possible to use substitution to yank [tex]ln(f(x))[/tex] out of the integral and leave us with
[tex]g(\int_{ln(f(a))}^\ln(f(b))} e^x } )[/tex]
With g(x) as what we pulled out of the integral. I'm very new to integration, but this idea has been puzzling me for a while. If this is possible, it would seem pretty dang handy when integrating. Then again, I'm playing with methods I've only recently taught myself (I came up with this while running on a tredmil, actually.) It's fully possible I misunderstood something or overlooking a rule that makes this impossible. Anyway, thanks for any information that flies my way.
I'm intrigued by what you're trying to do here, and am not too much a veteran at integration myself, but I don't understand where the g() came from. I can see your first step, as they are equivalent, and the second because they evaluate to the same thing.. but I don't see the g().
Well if as you say [tex]g(x) = \ln{f(x)}[/tex], i.e. g(x) is what we pulled out.
Now try evaluating your specific g(x):
[tex]g(\int_{ln(f(a))}^\ln(f(b))} e^x } ) = \ln{f(\int_{ln(f(a))}^\ln(f(b))} e^x })}[/tex]
Now if you plug g(x) back into the original integral you get a whole mess.
In reality your specific g(x) is the following:
[tex]g(\int_{ln(f(a))}^\ln(f(b))} e^x } ) = g(f(b)-f(a))[/tex] by the fundamental theorem of calculus, which still makes no sense when you plug it back into the original integral.
What you may be thinking of is u substitution. Suppose you had the following integral:
[tex]\int2xe^{x^{2}}dx[/tex]
then setting [tex]u = x^{2}[/tex] you get [tex]du = 2xdx[/tex] and the integral can be re-written as
[tex]\int e^{u}du[/tex]
and the rest of the integration is simple.
Hmm, I don't know if I fully follow. I'm not trying to integrate e to the power of something, but rather define a function in terms of [tex]e^{ln(f(x))}[/tex], which then becomes e to the power of something, and then integrate in terms of that. And yeah, I got the idea from u-substitution (hence I even plugged my original ln(f(x)) into the bounds of integration.)
I think I failed to convey myself. g( ) was a mistake, I was trying to put something 'outside' of the integral to represent what was removed. I'm not sure how to denote that though, so I just plugged the integral into a function -- I think that wasn't the best of ideas, and changed my intentions into something else.
Sorry it was confusing, I just tried to follow what you had ;p
Suppose you wanted to do u substitution on your original then
[tex] u = ln(f(x))[/tex] and [tex]du = \frac{f'(x)}{f(x)} [/tex]
which doesn't help you with the particular integration.
There may be an f(x) for which your idea is beneficial, but I can't think of one at the moment ;(
I think it would have to be a function s.t. [itex]f(x) \propto \frac{f'(x)}{f(x)}[/itex] in order to play nicely with the u-sub, no?
Nooooo! My dreams of becoming famous for finding a universal one step method of integration are dashed!
Okay, I'll admit it, I had a dream like that one time. =P
Yes. I guess you could have some horrendous integral like this:
[itex]\int g(x)f(x)dx[/itex] where [itex]g(x)=\frac{f'(x)}{f(x)}[/itex]
And for some reason you couldn't reduce the integral to just be f'(x)dx.
what the hell are you guys talking about?
This really makes absolutely no sense.
First, this ([tex]f(x)=e^{ln(f(x))}[/tex] ) only makes sense when f is a strictly positive function.
Second, maybe you try this "technique" with a specific f, say, f(x)=x^2+1, before doing anything.
To my understanding, the natural log of a value is the number which when used as the exponet of e brings it to that specific value. Hence I figured any output, y, of f(x), is the same as e to the power of the natural log of that value. That would be [tex]e^{ln(y)}[/tex], so I changed out y for f(x), since they're equivalent (f(x)=y.) I might be mistaken, I suppose that might should have been read f(x) ==> y (if that makes a difference?)
As for negative fuction outputs, those did come to mind. I'm not the formost expert on complex numbers, but I was under the impression that we could use the complex field to solve for any negative values the function yields. I recall, for example, reading that [tex]ln(-1)[/tex] is plus or minus [tex]i * pi[/tex]. That would mean if f(x)=2x, and x= -0.5 then [tex]e^{ln(2(-0.5))} = { e^{ln{(-1)} } = {e^{i*pi}[/tex].
Unless I'm completely mistaken...?
OK, so let's see it: calculate the integral of f(x)=2x from x=-1 to x=1 using your technique.
I tried, but I failed. I'm no good with using logorythms. That's a major problem with being self-taught, I don't know what I need to focus on learning and what I don't. Would you mind teaching me how to integrate this, or point me to a decent source? I probably need to invest in a real textbook, instead of these terrible study guides I have. As it is, I only understand elementary integration, and I haven't had much time to become creative when applying it either.
*edit
Wait... now I'm REALLY confused. I think I did solve it, but the results were impossible so I dismissed it.
I don't know now.
My tip is to give up on this method, get those real textbooks and relearn from the basics. To integrate what Doodle Bob said is quite easy if you look at its graph and the bounds. If you don't see that after this hint, you back to basics. No offense intended here.
kts123,
Although this method you came up with proved to be ineffective, don't let everybody telling you you're wrong discourage you. By defenition of psychology, intelligence is "the ability to think abstractly"..paraphrased. In other words, it is that kind of thinking that leads to great discoveries in mathematics; just because you don't discover a new method while you are in Calc I doesn't mean it won't ever happen. Keep it up.
Jimmy
FAQ: An idea for integration that has been bugging me.
1. What is the idea for integration that has been bugging you?
The idea for integration that has been bugging me is the use of artificial intelligence to streamline and automate the process of integrating different software systems.
2. Why do you think this idea is important?
I believe this idea is important because it can save time and resources for businesses and organizations that rely on multiple software systems. It can also improve overall efficiency and accuracy in data transfer and communication between different systems.
3. How would this idea be implemented?
This idea could be implemented by developing a software platform or tool that utilizes machine learning and natural language processing to identify and understand different software systems and their integration needs. It would then automatically create and execute integration solutions without the need for manual coding.
4. Are there any potential challenges or drawbacks to this idea?
Some potential challenges or drawbacks to this idea could include the initial development and training of the artificial intelligence, the need for ongoing maintenance and updates, and potential security concerns with data transfer between systems.
5. How do you see this idea impacting businesses and organizations?
I believe this idea has the potential to greatly impact businesses and organizations by simplifying and streamlining their processes and reducing the need for manual integration efforts. It could also lead to cost savings and improved productivity. However, it may also disrupt certain industries and job roles that are currently focused on software integration.
