HethensEnd25
- 28
an Ideal gas at T = 70 C and 1 bar undergoes following reversible
processes:
a: Adiabatically compressed to 150 C
b: then, cooled from 150 to 70 C at constant pressure
c: finally, expanded isothermally to the original state (T=70 C and P = 1 bar)
1-dU=dQ+dW
2-dU=CvdT
3-(T2/T1)=(P2/P1)(R/Cp) from TP(1-ϒ)/ϒ=constant
4-CpdT=dH
So far for part a) I have done the equation dU=dQ+dW, since it is an adiabatic process I have dQ=0, thus leaving dU=dW. I know that dW=-PdV so I can calculate dU=CvdT to get my change in internal energy. From there I calculated P2 using equation 3.
For b) knowing it is an Cp problem I used equation 4 having CpdT=dH where my change in temperature is 150 to 70 C
I am stuck on part c)
I know it is an isotherm that means that there is no change in temperature thus dU and dH are equal to zero since they are temperature dependent. So dQ=dW. Do I make it so that T is a constant and solve with partial derivatives giving me dT=(V/R)dP+(P/R)dV. With dT=0 we get -PdV=VdP. Using the ideal gas equation to give V=RT/P ==> -(RT/P) dP. Integrating gives me -RTln(P2/P1)
My problem is I don't know what pressure to use. Do i just use the pressures calculated in my part b going from there back to the original state?
