An Impossible momentum problem?
In summary, two identical steel marbles, one stationary and one with a mass of 45 g, collide obliquely with an angle of 55 degrees between their original directions. The collision is perfectly elastic and the question asks for the angle between the direction of the target marble and the original direction of the incident marble. Using the equations for momentum and force, and applying the conservation of linear momentum, you can solve for the angle.
pokeefer
42
A 45 g steel marble collides obliquely with an identical stationary marble, and continues at 55 degrees to its original direction. The collision is perfectly elastic. What is the angle between the direction taken by the target ball and the original direction of the incident ball? (2 marks)
Momentum = mass x velocity
Change in momentum = change in mass x velocity
Force = Change in momentum / Time
P1 + P2 = P1' + P2'
M1V1 + M2V2 = M1V1' + M2V2'
Without knowing their velocities I find it really difficult to figure this question out.
First, before the collision, find the initial momenta in the x and y directions.
Then after the collision, find the momenta in the x and y directions.
Application of conservation of linear momentum will give you two equations.
You are told that they collide elastically, so what quantity is conserved here?
FAQ: An Impossible momentum problem?
What is an Impossible Momentum Problem?
An Impossible Momentum Problem refers to a situation where the momentum of an object cannot be calculated or predicted due to a lack of information or a violation of physical laws.
How do you identify an Impossible Momentum Problem?
An Impossible Momentum Problem can be identified by looking for inconsistencies or contradictions in the given information, such as an object having both a velocity and a mass of zero.
What causes an Impossible Momentum Problem?
An Impossible Momentum Problem can be caused by a variety of factors, including missing or incorrect data, a misunderstanding of physical laws, or a violation of the principles of conservation of momentum.
How do you solve an Impossible Momentum Problem?
Solving an Impossible Momentum Problem requires carefully examining the given information to identify any inconsistencies or violations of physical laws. If necessary, additional data may need to be gathered or assumptions may need to be made in order to solve the problem.
Can an Impossible Momentum Problem be solved?
In most cases, an Impossible Momentum Problem can be solved by carefully analyzing the given information and making reasonable assumptions. However, there may be rare cases where the problem remains unsolvable due to fundamental violations of physical laws.
