An infinite ladder of resistors
The discussion centers on calculating the equivalent resistance (RT) between points a and b in an infinite ladder network of resistors, where side resistors (Rs) are equal and different from center resistors (Rc). To find RT, one can use recursion by noting that the entire ladder consists of one rung plus another identical infinite ladder. Additionally, participants suggest deriving a general expression for the potential difference between points c and d, relating it to Rs, Rc, RT, and the potential difference Vab between points a and b. The complexity arises from the infinite nature of the circuit, prompting users to analyze finite versions for pattern recognition. Understanding this infinite arrangement is key to solving the problem effectively.
phys121
The network of resistors shown extends off to infinity. The resistors on the
sides of the “ladder”, RS, are equal to each other,but different from the resistors in the center of the ladder,Rc
.....Rs........Rs.....Rs
a------^^^^^------c---------^^^^^------------^^^^^------------etc.
......>Rc......>Rc.....>Rc
b------^^^^^------d---------^^^^^------------^^^^^------------etc.
.....Rs......Rs......Rs
1) find a general expression for the resistance RT between points a and b.
2) find a general expression for the potential difference between points c and d in
terms of the Rs , Rc , Rt , and the potential difference between points a and b, Vab . Any Help would be very much appreciated. have been sitting her for many hours now just stuck!
Ps. Please ignore all the full stops, it was the only way to make the circuit look like it should. So they actually mean nothing.
Between the two 'ladder' sides there is a resistor Rc just in case its not 100% clear. thanks in advance
Well this could have been a classic sum had been an infinite maze. But its quite easy as it s a ladder. The thing you have to note is that this is an infinite arangement.Lets say that the resisatnce betwen a and b is R. Then you can assume that after the c d branch you can replace the remaining ladder with R.
I suggest you work out the resistance for a couple of finite ladders to see if there is a general formula to which you can apply a limit.
On second thought you can use a recursion relationship. Remember that the whole ladder is one rung plus another identical infinite ladder.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 27 ·
