An interesting magnetic physics question about permanent magnets
In summary, the conversation discusses the potential effects of a powerful permanent magnet on a steel core and the possibility of stopping all flux in the core through the use of a tightly wrapped coil. Two hypotheses are presented, one proposing that the current in the coil would need to equal the coercivity of the magnet, while the other suggests that the magnet is already producing maximum flux and a small opposing MMF would stop all flux. The speaker is unsure and does not have enough knowledge to provide a direct answer to the question.
nickw1881
Imagine for a moment a steel core with no air gap, that is driven to saturation by a powerful permanent magnet. Imagine next that a coil is wrapped around some section of that core some distance away from the magnet, such that their only flux linking is through the saturated core.
The magnet is typical, but powerful enough to saturate the core: it has typical magnet ratings, Hc for its coercivity, Br for is remnant flux. The coil is magic, capable of supporting any amount of current needed for the experiment. The coil is also wrapped very tightly around the core.
What amount of MMF (H) would be put through the coil in order to stop all flux in the core?
One hypothesis is that the current in the coil would need to equal the Hc rating of the magnet in order to stop all flux in the core. My reasoning is that if the coil were to have just a small amount of current, the core would come out of saturation for a moment, allowing the magnet to send yet more flux into the core.
Another hypothesis is that the core is simply a very large reluctance, and the magnet is already producing as much flux as possible given its coercivity. If just a small amount of opposing MMF were generated in opposition to the magnet, all flux should stop.
What do you think?
If I understand your scenario, the opposing magnetic field of the coil would magnetize the core opposite to that of what the permanent magnet is trying to do, though needing to be of a strength greater than that of the permanent magnet.
If not glued to the core, the permanet magnet would fall off, or perhaps fly off.
Still, just my thoughts. I do not have the knowledge to directly answer your questions.
Related to An interesting magnetic physics question about permanent magnets
1. How do permanent magnets work?
Permanent magnets work by creating a magnetic field through the alignment of their microscopic magnetic domains. These domains are made up of atoms with unpaired electrons, which act as tiny magnets. When these domains are aligned, the overall magnetic field is strengthened and the magnet is able to attract or repel other magnets or magnetic materials.
2. Can the strength of a permanent magnet be increased?
No, the strength of a permanent magnet cannot be increased. The strength of a magnet is determined by the material it is made of and the alignment of its magnetic domains. Once a magnet is created, its strength is fixed and cannot be changed.
3. What makes a material magnetic?
A material is magnetic when it contains atoms with unpaired electrons. These unpaired electrons create a tiny magnetic field around each atom, and when the atoms are aligned in the same direction, the overall magnetic field is strengthened.
4. Can permanent magnets lose their magnetism?
Yes, permanent magnets can lose their magnetism over time. This can happen due to exposure to high temperatures, strong magnetic fields, or physical damage. When a permanent magnet loses its magnetism, it is known as demagnetization.
5. How can I test the strength of a permanent magnet?
The strength of a permanent magnet can be tested using a gaussmeter, which measures the strength of a magnetic field. Alternatively, you can also test the magnet's strength by seeing how many paperclips it can hold or by observing how far away another magnet can be before it is attracted to the magnet being tested.
