coquelicot
- 299
- 67
- TL;DR Summary
- critical points of a function on "critical lines"
Hi all,
I have recently faced some problem about distances between two curves, and (re?)"discovered" an interesting point that I would like to share with you.
In the following, we consider a function of two variables ##f(x,y)##, but it should be clear that the definitions and the result is valid for functions of more variables.
First, let me set few definitions:
Let ##f(x,y)## be a differentiable function and ##(x_0, y_0)## be a point in its domain. A critical partial line of f in the neighborhood of ##(x_0, y_0)##, with respect to the variable ##y##, is a function ##\varphi(x)## defined in the neighborhood of ##x_0## such that ##y_0 = \varphi(x_0)## and $$ {\partial f \over \partial y} (x, \varphi(x)) = 0.$$
Similarly, a critical partial line of f in the neighborhood of ##(x_0, y_0)## with respect to the variable ##x##, is a function ##\psi(y)## defined in the neighborhood of ##y_0## such that ##x_0 = \psi(y_0)## and $$ {\partial f \over \partial x} (\psi(y), y) = 0.$$
If furthermore the point ##(x_0, y_0)## is such that
$$ {df (x, \varphi(x))\over dx}\bigg|_{x=x_0} = 0$$
(resp. ## {df(\psi(y), y)\over dy}\bigg|_{y = y_0} = 0##), then we say that ##(x_0, y_0)## is a critical point of ##f## on the critical partial line ##\varphi## (resp ##\psi##).
With these definitions, we have the following theorem:
The critical points of ##f## on its critical partial lines are the critical points of ##f##. In particular, they do not depend on the variable with respect to which the critical partial line refers to.
Before I give the (very simple proof), let me give an application:
Let ##y = f(x)## and ## y = g(x)## be two curves defined in open intervals. Assume that ##P_1 = (a_1, f(a_1)) ## is a point of curve ##f## that minimize (resp. maximize) the distance ##d((x_1, f(x_1), g)##, and ##P_2= (a_2, g(a_2))## is a point of ##g## that minimize (resp. maximize) the distance ##d((x_2, g(x_2)), f)##.
Then ##(a_1, a_2)## is a critical point of the distance function
$$h(x_1, x_2) = (x_1 - x_2)^2 + (f(x_1) - g(x_2))^2. $$
Furthermore, the straight line between ##P_1## and ##P_2## is orthogonal to both curves (this is the not so easy point).
Proof: The distance of a point ##(a_1, f(a_1))## to curve ##g## is given by
$$\min_{x_2} h(a_1, x_2).$$ A point of minimum ##a_2## exists and must fulfill
$${\partial h (a_1, a_2)\over \partial x_2} = 0.$$
Moreover, the straight line from ##(a_1, f(a_1))## to ##(a_2, g(a_2))##
is orthogonal to curve ##g##, as is well known.
By the implicit function theorem, there is a function ##\varphi(x_1)## defined in the neighborhood of ##a_1## such that
$${\partial h (x_1, \varphi(x_1))\over \partial x_2} = 0.$$
So ##\varphi## is a critical partial line of ##f## with respect to ##x_2##.
Thus, the problem reduces to find a point ##a_1## that is a critical point of ##h## on ##\varphi##.
By the theorem, ##(a_1, a_2= \varphi(a_1))## must be a critical point of ##f##.
Furthermore, we have seen that the straight line ##(a_1, f(a_1))-(a_2, g(a_2))## is orthogonal to ##g##. By symmetry (which is not evident a priori), taking a critical partial line of ##f## with respect to ##x_1##, it is also orthogonal to ##f## (q.e.d).
Proof of the theorem:
Assume for example that ##\varphi## is a critical partial line of ##f## with respect to ##y## at ##(x_0, y_0)##.
We have
$${df (x, \varphi(x))\over dx}\bigg|_{x=x_0} = {\partial f(x_0, \varphi(x_0))\over \partial x} + \varphi'(x_0) {\partial f(x_0, \varphi(x_0))\over \partial y}. $$
Hence the condition
$${\partial f(x_0, y_0)\over \partial x} = 0 \ {\rm and} \ {\partial f(x_0, y_0)\over \partial y} = 0$$
is equivalent to the condition
$${df (x, \varphi(x))\over dx}\bigg|_{x=x_0} = 0 \ {\rm and} \ {\partial f(x_0, \varphi(x_0))\over \partial y} = 0 ,$$
but from the hypothese,
$$ {\partial f(x_0, \varphi(x_0))\over \partial y} = 0 $$
since ##\varphi## is a critical line of ##f## at ##(x_0, y_0)##, with respect to ##y## (q.e.d.)
We have
Hence the condition
