An isomorphism maps a zero vector to a zero vector?
In summary, the lemma requires a vector v in the vector space V because every vector space must have at least one vector (including the zero vector). This is due to the property that every vector space must have a zero vector, and therefore cannot be empty. The proof for the lemma still holds when taking v as the zero vector.
df606
(Apologies for ascii art math, I don't know latex. Also apologies if this is in the wrong forum.)
Why, in this lemma, must there be a vector v in V? That is, why must V be nonempty?
An isomorphism maps a zero vector to a zero vector.
Where f:V->W is an isomorphism, fix any vector v in V. Then f(0 vector represented with respect to V) = f(0 * vector v) = 0 * f(vector v) = 0 vector represented with respect to W.
The answer is given as "No vector space has the empty set underlying it. We can take vector v to be the zero vector."
So actually, I'm not trying to solve the problem. I'm just having a hard time understanding the answer.
What does it mean by "no vector space has the empty set underlying it?" Does that mean no vector space consists entirely of the empty set? The way it's phrased makes it sound like the vector space can include the empty set along with other sets. Wouldn't you be able to take vector v to be the zero vector in either case? Or is there no zero vector for the empty set? Even if you couldn't, why would you need to be able to take vector v to be the zero vector? A scalar zero times anything should be the zero vector, right? Or am I misinterpreting that, in that you're not supposed to take v as the zero vector?
I haven't studied in weeks, so these are possibly/probably stupid questions, I feel like I've forgotten all the basic math I learned when I started linear algebra.
They sure phrased it in a very incomprehensible manner. Let me try to clear things up for you.
A vector space is a certain set with an addition and a scalar multiplication on it which satisfies certain properties. One of these properties is
[tex]\exists 0\in V:~\forall v\in V:~0+v=v=v+0[/tex]
So in ANY vector space there must exist a zero vector. In particular, every vector space must be nonempty (since there must at least be one vector in it: 0). This is what they mean with "there is no vector space with the empty set underlying it", it's just phrased horribly. A translation is "every vector space is nonempty".
So, now we know that every vector space has a vector. So your lemma works out. In particular, we can always take v=0 in your lemma, and the same proof will hold!
Aha. That clears things up. Thanks!
Related to An isomorphism maps a zero vector to a zero vector?
1. What is an isomorphism?
An isomorphism is a mathematical concept that describes a one-to-one correspondence between two mathematical structures. In simpler terms, it is a function that preserves certain properties between two objects.
2. What is a zero vector?
A zero vector is a vector with all of its components equal to zero. In other words, it has no direction and no magnitude.
3. How does an isomorphism map a zero vector to a zero vector?
An isomorphism maps a zero vector to a zero vector by preserving the zero vector property, which means that the output of the function will also have all its components equal to zero. This is a necessary condition for a function to be considered an isomorphism.
4. What is the importance of an isomorphism mapping a zero vector to a zero vector?
An isomorphism mapping a zero vector to a zero vector is important because it ensures that the structure and properties of the original vector are maintained in the mapped vector. This is crucial in many mathematical applications, such as in linear algebra and group theory.
5. Can an isomorphism map a zero vector to a non-zero vector?
No, an isomorphism cannot map a zero vector to a non-zero vector. This is because it would violate the zero vector property and the one-to-one correspondence between the two structures would not be preserved.
  • Linear and Abstract Algebra
