An issue with length contraction
student34
639
I have read that length contraction is real and not just an illusion. However, when I compare an object at rest with an observer and the object in motion relative to another observer, I see that instead of there being a real length contraction, there is simply a difference in the part of the object being observed. In other words, the two observers are just looking at two different parts of the object.
To illustrate my issue. This video attempts to explain how length contraction is not an illusion, but it seems to only enforce my issue. Watch starting at 7:05 to 7:20,
The line at an angle is the length of the ship at rest, and the horizontal line (contraction) is the length of the ship as observed in motion.
When we think of the ship as just one large structure extending through time, aren't those lines just depicting different parts of the ship?
Then isn't length contraction similar to saying that a 3d cube, with 1 cm^2 sides, has a length contraction of 1 cm and a rest length of 2^(1/2)L?
  • Skeptical
Likes PeroK
We have to be careful with "looks" here, because length contraction is what is being measured, i.e. coordiates position and time.
When we look at objects, we need to account for how the light emitted from the object is traveling to our eyes/detector
Likes topsquark and vanhees71
Not sure how you're getting this. Both observers measure the length between the same two points of the object.
You mean if a football field was moving at in some inertial reference frame, giving a gamma factor of , then an attempt to measure the length of the field between the goalposts atveach end would somehow instead measure the distance from one set of goalposts to the halfway line?
That has got to be nonsense! The observers would measure the distance from goalpost to goalpost.
Likes topsquark
The points are in different positions in time, causing the difference in length, right?
Likes Dale
To measure the length between two points of a moving object, the observer must measure their positions at the same time. And, yes, the two frames will not agree that the measurements were made at the same time -- that's the relativity of simultaneity. But they certainly measure the same two points on the object.
Likes topsquark, PeterDonis and PeroK
When an object is at rest relative to you, you measure the length from the tip to the end to be . When the same object is moving relative to you, you measure the length from the tip to the end to be , and No more an illusion as the measurement of your monitor right in front of you.
Likes topsquark
That isn’t too far off from what actually happens though. The difference is that we are looking at 4D objects, so while they are both measuring from goalpost to goalpost in space, in time they are measuring differently. One of them is measuring with time lines straight across the pitch and the other is measuring with time lines diagonally across the pitch.
  • Skeptical
Likes PeroK
I don't know what everyone else is seeing, but I clearly see different points on the "structure" of the ship that is extending through time.
Realize that those slanted lines on the diagram represent the positions of the same two points on the object! The two observers disagree on when the measurements were made but not on the points being measured.
Likes Dale
I would strongly recommend against using imprecise words like “real”. It is far better to use words with a defined and agreed-upon meaning.
Length contraction is measurable, it is also frame-dependent. Some people will call it real because it is measurable, and some people will call it not-real because it is frame-dependent. But everyone should agree that it is measurable and frame-dependent. So the designation of real or not-real doesn’t convey any information.
Likes nasu, topsquark and PeroK
The term "frame-dependent" can cause confusion here. Actual measurement results are invariants; that means they are not "frame-dependent" in at least a very common usage of that term.
Length contraction as an actual measurement depends on the state of motion of the object relative to the measurement apparatus; in other words, a measurement of the length of an object that is moving relative to the measurement apparatus is represented by a different invariant than a measurement of the length of the same object by measurement apparatus at rest relative to the other.
Each of these different invariants could, in principle, be described using any coordinates you like; for example, you could describe the invariant that represents the measurement of the object's length by an apparatus at rest relative to the object, using coordinates in which the object is moving (and in which the measurement apparatus is also therefore moving). The individual components of things like 4-vectors in the coordinate representation of any invariant are "frame dependent" in the sense of depending on which coordinates you choose; but the invariants themselves are not.
Likes Dale and topsquark
This is what you measure the length of the rocket to be, moving relative to you:
And this is what an observer in the rocket (at rest relative to the rocket) would measure the length to be:
Note that both observers measure the length bewteen the tip and the tail of the rocket at the same time in their rest frames. And those lengths won't be the same.
If I had 2 parallel strings set up like the worldlines of the endpoints of the ship shown in the video, we would not think that any 2 points on one of the strings are the same point.
Likes topsquark
But those worldlines aren't "things" like string -- they represent the position of some specific piece of the object as a function of time. Two points on the line are not different parts of the object, just that same part at a different time.
But the other end of the ship is in a different time.
  • Skeptical
Likes PeroK
Not when you measure the length between tip and tail in your rest frame.
Then think about it this way. We could have a scenario where the first point of the nose of the ship does not even exist at the time of both observers measuring the ship. For example what if the nose were built really fast after the 2 clocks agreed on time. This would prove that these two points at the nose of the ship are not the same just like 2 separated points on a string are not the same.
  • Skeptical
Likes PeroK
I meant to say that the 2 separated points in the illustration (at the nose of the ship) are at differing times.
There is no single "time at which both observers measure the ship". That is what the relativity of simultaneity means.
In the drawings in post #13, there are three events in spacetime. At the first event (the one on the left in both diagrams), both observers record the spatial position of the rear of the ship.
At the second and third events (the two different dots on the right in the two different diagrams), the two observers respectively record the spatial position of the front of the ship.
Events #1 and #2 happen at the same time according to the observer who sees the rocket as moving.
Events #1 and #3 happen at the same time according to the observer who is on the rocket and at rest relative to it.
In the alternate scenario you propose in the quote above, the nose of the ship is not yet built at event #2, but has just been completed at event #3. In this scenario, the observer who sees the rocket as moving would not be able to measure the rocket's length at the time at which events #1 and #2 happen in his frame, because the rocket's nose would not have been built yet. He would have to wait until the time at which event #3 happens in his frame, and his length measurement would involve event #3, at the nose, and a different event, event #4, at the tail (at whatever point on the tail's worldline was simultaneous with event #3 in his frame).
Likes topsquark, Dale, Doc Al and 1 other person
Ok, I agree, but I do not see how any of this conflicts with what I am saying.
You said:
There is no such time. At the very least, you need to clarify what you meant by the phrase I just quoted, since what it says does conflict with what I posted in post #20--that's why I made that post.
Likes phinds, russ_watters and topsquark
PeterDonis said:
You said:There is no such time. At the very least, you need to clarify what you meant by the phrase I just quoted, since what it says does conflict with what I posted in post #20--that's why I made that post.
Ok, what I said was not accurate.
The heart of my issue is trying to understand whether or not there really is a length contraction or just a different perspective.
Forget this question. It is a meaningless question because it focuses on the meaningless word “really”
Likes topsquark and PeterDonis
There is a measurable length contraction. The underlying reason is that the two frames take different 3d cross sections through the 4d worldtube as "the object, now" and those cross sections have different lengths. Whether you regard that as "really length contraction" or not is up to you. I wouldn't regard "really" as a helpful distinction.
I still have the problem without the word "really". I will stop using it.
Your reply adds to my concern. If what you say is correct, then why is it even called length contraction when there doesn't seem to be any reason for it to be called that.
The case of the rocket is a measurement that doesn't appear to have physical implications. That's why people think it is un-physical/an illusion. So perhaps it would useful to look at cases where there are real physical implications, such as with muon decay observations or relativistic space travel?
Or, from a Newtonian perspective: does it matter if different observers measure a car's speed differently - is the difference physically "real"? Well it does matter if it collides with a "stationary" object, in which frame the object was stationary.
Likes topsquark
Because the terminology predates Minkowski rewriting relativity in terms of geometry. In fact it goes back to Fitzgerald contraction, which was believed to be a compressive effect of the ether when one moved through it. The name has stuck. It's hardly the only infelicitous naming convention in physics - see conventional current, for example.
Likes topsquark
Without that word I don't see the problem. Can you re-state it?
Likes topsquark
  • #31
I suspect that if and when AI manages to understand physics, it will require only a very basic mathematical vocabulary and will not try to understand things in human terms. AI would probably not need the concepts of time dilation, length contraction and simultaneity; or, "worldtubes".
But, as a human being you need to build up your understanding using all manner of intermediate and possibly unnecessary concepts, such as length contraction.
It concerns me that you get sidetracked by all these extraenous ideas and your concerns over terminology seem to be at best pointless. Why not length contraction? How much study time are you proposing to waste musing over that question?
Likes topsquark
  • #32
Is there a length contraction, or is it only a different observation?
  • #33
And another way to look at it is that there is no form of words that exactly captures what length contraction is. So if we changed the name somebody else would be here arguing that the new name isn't right either. That's why we tell people to concentrate on the maths, which is precise. Length contraction is just a label for a section of the maths and some related possible experimental measures.
Likes topsquark and robphy
  • #34
This is a false distinction. Length contraction is the phenomenon that the measured length of a moving object is less than that of the same object when it's stationary.
If you mean "is there a compressive stress causing the reduction in length" then the answer is no.
Likes topsquark, Motore and Dale
  • #35
The reason I started this thread is because I wanted to know if I was interpreting this part of GR incorrectly. It helps me to know what the consensus here is.
13K
9K
