An object suspended by a spool of string. (Angular momentum problem)
In summary, to determine the tension in the string, acceleration of the object, and speed at which it hits the floor, you can use Newton's second law of motion in both its linear and angular forms, taking into account the forces and torques acting on the object and the moment of inertia of the reel. This will allow you to solve for the desired values and obtain more accurate results.
letsfailsafe
An object with a mass of m = 4.80 kg is attached to the end of a string wrapped around a reel of radius R = 0.230 m and mass M = 3.00 kg. The reel is a solid disc. The suspended object is released from rest 1.90 m above the floor.
http://imgur.com/ElfqPSX
a) Determine the tension in the string.
b) Determine the acceleration of the object.
c) Determine the speed with which the object hits the floor.
[itex]\tau[/itex] = I [itex]\alpha[/itex]
T = m(g - a)
E = (0.5)(I)([itex]\varpi[/itex])2
mg = [itex]\tau[/itex] = I [itex]\alpha[/itex]
mg = I [itex]\alpha[/itex]
mg = (1/2)(MR2)([itex]\varpi[/itex]
mg = (1/2)(MR2)(a/R)
mg = (1/2)(MR)(a)
a = (2mg)/(MR)
a = ((2)(4.8)(9.8))/((3)(0.23))
a = 136.34 m/s2
There is no way this is right. This is one of the many methods I have tried and all the values were ridiculously high so I am posting a question here as a last resort.
T = m(g - a)
I think here is where the error starts.
For starters, you're mixing force and torque. mg is a force, not a torque.
Secondly, the force applied to the disk is not mg, rather it's the tension of the string T. Putting that in other words, the tension on the string is not mg, it's something less than that. [Edit: btw, you already have this in your relevant equations.]
To solve this problem, I suggest using Newton's second law of motion in two different ways. First, use the more conventional form of the law applied to the mass, m. The sum of all forces applied to the mass m is equal to ma, the mass times its acceleration, a.
[tex] \sum_n \vec F_n = m \vec a [/tex]
Then do the same, but for the angular version with torques and moment of inertia, and apply that to the disk.
[tex] \sum_n \vec \tau_n = I \vec \alpha [/tex]
Combine that with your knowledge of the relationship betwee [itex] \alpha [/itex] and [itex] a [/itex], and you have enough information to solve the problem.
FAQ: An object suspended by a spool of string. (Angular momentum problem)
What is angular momentum?
Angular momentum is a physical quantity that measures the amount of rotational motion of an object. It is calculated by multiplying an object's moment of inertia (its resistance to rotation) by its angular velocity (how fast it is rotating).
How is angular momentum related to an object suspended by a spool of string?
In this scenario, the angular momentum of the object is conserved, meaning it remains constant throughout the motion. This is because there are no external forces acting on the object, so there is no torque (the rotational equivalent of force) applied.
What is the moment of inertia?
The moment of inertia is a measure of an object's distribution of mass around an axis of rotation. In simpler terms, it determines how difficult it is to change the rotational motion of an object.
How does the length of the string affect the angular momentum?
The length of the string does not affect the angular momentum of the object. As long as the string remains taut and the object's distance from the axis of rotation does not change, the angular momentum will remain constant.
What happens to the angular velocity if the string is shortened?
If the string is shortened, the angular velocity will increase in order to maintain the object's constant angular momentum. This is because the moment of inertia decreases as the object's distance from the axis decreases, so the angular velocity must increase to compensate.
