An Open Cylindrical Tank of Acid....
In summary: Remember that sqrt{ab} = \sqrt{a}\sqrt{b}.In summary, the problem involves an open cylindrical tank of acid at the edge of a table, with a small hole in the side at its base. Using Bernoulli's equation and equations for gravity and velocity, the distance (x) from the foot of the table to where the acid hits the floor can be calculated. The correct equation is \Delta x=\sqrt{2gh_{tank}} \sqrt{\frac{2h_0}{g}} which gives a final answer of 2.48\cdot 10^0\ m.
The-Mad-Lisper
An open cylindrical tank of acid rests at the edge of a table [itex]2.20\cdot 10^0\ m[/itex] above the floor of the chemistry lab. If this tank springs a small hole in the side at its base, how far from the foot of the table will the acid hit the floor if the acid in the tank is [itex]7.00\cdot10^{-1}\ m[/itex] deep?
Let [itex]\rho[/itex] be the mass density of acid, [itex]g[/itex] be the acceleration of gravity, [itex]h_{tank}[/itex] be the depth of the tank, and [itex]h_0[/itex] the height of the base of the tank.
[itex]p_1+\rho g y_1+\frac{1}{2}\rho {v_1}^2=p_2+\rho g y_2+\frac{1}{2}\rho {v_2}^2[/itex] (Bernoulli's Equation)
[itex]\Delta x = vt[/itex]
[itex]\frac{1}{2}gt^2=h_0[/itex]
[itex]t^2=\frac{2h_0}{g}[/itex]
[itex]t=\sqrt{\frac{2h_0}{g}}[/itex]
[itex]\rho g h_{tank}=\frac{1}{2}\rho v^2[/itex]
[itex]gh_{tank}=\frac{1}{2}v^2[/itex]
[itex]v^2=2gh_{tank}[/itex]
[itex]v=\sqrt{2gh_{tank}}[/itex]
[itex]\Delta x=\sqrt{gh_{tank}} \sqrt{\frac{2h_0}{g}}[/itex]
[itex]\Delta x=\sqrt{\frac{2gh_{tank}h_0}{g}}[/itex]
[itex]\Delta x=\sqrt{2h_{tank}h_0}[/itex]
[itex]\Delta x=\sqrt{2\cdot 7.00\cdot 10^{-1}\ m\cdot 2.20\cdot 10^0\ m}[/itex]
[itex]\Delta x=\sqrt{3.08\cdot 10^0\ m^2}[/itex]
[itex]\Delta x = 1.75\cdot 10^0\ m[/itex]
Unfortunately, [itex]1.75\ m[/itex] is not the correct answer. Perhaps I am not setting up Bernoulli's equation correctly for this problem.
No, the problem is not with the Bernoulli equation.
You have:
and
when you combine these two equations:
you dropped one of the factors of 2 under the radical sign for some reason.
Likes The-Mad-Lisper
FAQ: An Open Cylindrical Tank of Acid....
1. What is an open cylindrical tank of acid?
An open cylindrical tank of acid is a container used to store and transport acid, which is a corrosive chemical compound. The tank is cylindrical in shape with one open end, allowing for easy filling and emptying.
2. What types of acid can be stored in an open cylindrical tank?
Various types of acid can be stored in an open cylindrical tank, including sulfuric acid, hydrochloric acid, nitric acid, and acetic acid. The type of acid will depend on the intended use and storage requirements.
3. What are the safety precautions for handling an open cylindrical tank of acid?
When working with an open cylindrical tank of acid, it is important to wear protective gear such as gloves, goggles, and a face mask. The tank should also be stored in a well-ventilated area and away from incompatible substances.
4. How do you clean and maintain an open cylindrical tank of acid?
To clean an open cylindrical tank of acid, it is recommended to use a neutralizing agent such as baking soda or lime to neutralize the acid. The tank should then be rinsed thoroughly with water. Regular maintenance of the tank may include checking for any signs of damage or corrosion, and repairing or replacing parts as needed.
5. What are some common uses for an open cylindrical tank of acid?
An open cylindrical tank of acid is commonly used in industries such as chemical manufacturing, metal processing, and water treatment. It is also used in laboratories for experiments and in educational settings for demonstrations.
