An unusual but not too technical thermodynamic question for you guy/gals
In summary: now my q. is, can i still do what i had in mind, or would it violate some other rule that i'm not aware of. in summary, can i still run a watercooling system with a core in a ducted inlet/outlet?
slicey
an unusual but not too technical, thermodynamic question for you guy/gals
hi, I've got an unusual q. that i don't think computer forums members
can handle too well. they know their watercooling very well and that's
what my q. relates to. but more specifically it has to do with
system effects of ducted DC fans(thermodynamics). you see, i want to cool my
pc with a watercooling circuit, consisting of a pump, heater
core, CPU waterblock and one or both of my 6.75",24V, 283CFM,
.75"H2o Papst fans. the purpose is low noise output/cost.
here's the deal, I'm trying to design a wood enclosure, that
contains a 6" by 11" by 2"(louvered fin portion) heater core.
all the watercooler boxes I've seen, the builders, just mount
the fan(s) and radiator/core to the exterior walls of their
external boxes. this allows the noise from the fan(s) a more
direct path back to your ears. same goes for the fan sound
coming through the core as well. this will not do. OK, so i
spent a few weeks learning a little about what you guys/girls
know. keeping the airflow velocity low, helps to keep the
sound level down. no turns in the ducting, something like
2.0-2.5x the fan dia., by inlet or outlet. air in a duct
doesn't like being squeezed or expanded suddenly. i could go
on, but you know this stuff a lot better than i do. don't
leave this post yet, please. what i had in mind before my
research enlightened me some, was to have a core installed in
a ducted inlet/outlet, where the air pathway went back and
forth at least once, on both sides of the core after
entering/exiting the enclosure. i hope that made sense, for i
know not how to import and post a pic. because of what i
learned, i violated many of the rules of system airflow and
noise. and the part i just don't know, but I'm hoping someone
can tell me if I'm right or wrong is this; i have two of these
fans that can really move a lot of air each(in parallel, a
whole lot). also, in series they can provide greater pressures
and i understand these facts only apply to a properly,
respectively matched system, impedance wise. but these fans
won't need to run anywhere near 24volts, even at my 5000ft.
elevation in order to properly cool the water passing through
my core, which is why I've already built a variable DC supply.
CAN'T I STILL JUST BUILD MY ORIGINAL DUCTED ENCLOSURE, THE WAY
I DESCRIBED, WHICH I THINK WILL STILL DO A BETTER JOB OF
ACOUSTICALY ISOLATING THE SYSTEM NOISE FROM REACHING MY EARS?
there i finally asked my "question", almost. i mean from what
i learned, the ducting should be straight before and after any
fans and be long enough to allow the airflow to develop a
smooth(laminar?) flow, also, without any obstructions near the
duct's inlet/outlet? i know there's more to it but that's the
basics of what i learned. I'm just a landscaper. i do hope you
can help me, not many people ever respond to my questions in
the computer forums.
thank you! slicey
i am sorry, i posted this in the wrong forum. i now realize this should be in Mechanical and Aerospace Engineering forum.
Computer science news on Phys.org
Without looking at any diagram or getting into specifics, I would relay these things to think about:
1) In any application with a fan, especially those that move a lot of air, the ducting noise will be far less than the noise created by the fan tip/air interaction. Especially when the fan tips are moving at a considerable speed.
2) If I have a good mental picture of what your configuration is like, I would stick to your guns in terms of the ducting arrangement and work more on isolating the fans from the enclosure. You will get a nice dampening by using wood for the box, but you may want to look into further dampening by elastomer mountings for the fans. Possibly also placing foam along the inside of the entire box.
3) In your case in which the flow is along a relatively short path, I would think less about the noise created by adding bends in your flow circuit and consider them more along the lines of effecting the total flow, i.e. frictional effects. The larger you can make the ducting, you will decrease friction and reduce the airstream velocity, thus less noise.
4) The straight runs of ducting prior to and after the fan will help to get the highest efficiency from the fan by having a fully developed and symmetrical velocity profile entering the fan face. This will mean that, in theory, every spot on the fan face is receiving the same amount of air as it's counterpart on the exact opposite side of the face.
If you can figure out how to post a schematic that would really be a help.
thank you very very much, Fred. i have to head into the valley to get some supplies. (payson,az-scottsdale[80miles one way]) therefore, it'll be late before i get back and post pic. please don't forget me, i WILL return.
slicey
Fred, couldn't get you a pic, but everythin you said, except for a little bit about paragraph 3, i am acutely aware of. so, back to what you said in paragraph 3. i considered making the ducting larger but how much larger? but, before that q. can be answered, i must 1st know if the fans would better serve me in a series or parallel configuration for my enclosure of limited size. the gross volume of the enclosure is whatever could be made from a 4 by 8 sheet of 3/4" MDF. some of that material would have to be used to make the interior partitions that would form the ducting(passage ways), much like transmission-line speakers, chosen by some loudspeaker enclosure designers.
i was originaly planning on some kind of lining in the duct walls, like the padding found under automotive carpets. but this too adds friction. thus reducing airflow. I'm so confused! mainly w/ the fan configuration.
Sorry I didn't get back to you in so long.
If your box has good venthillation, I would run the fans parallel. That will give you a greater increase in overall flow. If you were to run the two in series, you would, in theory, get more head increase which you really don't need in your case.
In terms of thinking about the velocity of the air, it's definitely a tradeoff. The heat transfer you want will improve as a function of Reynolds number, which is a function of the free stream velocity. However, with that velocity, you will gain noise. It's always a trade off.
I wouldn't worry too much about lining the inside of the ducts, unless you were to line them with something to reduce the frictional effects. If you were to somehow wrap the outside of the ducts that would help deaden the sounds resonating from the ducts.
Related to An unusual but not too technical thermodynamic question for you guy/gals
1. What exactly is thermodynamics?
Thermodynamics is the branch of physics that deals with the relationships between heat, energy, and work. It studies the movement and conversion of energy in various systems.
2. How does thermodynamics apply to everyday life?
Thermodynamics is applicable to a wide range of phenomena, from the functioning of engines and refrigerators to the heating and cooling of buildings. It also plays a role in the formation of weather patterns and the behavior of chemical reactions.
3. What is an unusual but not too technical thermodynamic question?
An example of an unusual but not too technical thermodynamic question could be: "If you were to boil water in a vacuum chamber, would it boil at a lower or higher temperature compared to boiling it in an open pot?"
4. What is the second law of thermodynamics?
The second law of thermodynamics states that the total entropy of an isolated system always increases over time. In simpler terms, it means that energy tends to disperse and systems tend to become more disordered over time.
5. How does thermodynamics relate to the concept of energy conservation?
Thermodynamics is closely related to the principle of energy conservation, which states that energy cannot be created or destroyed, only transformed from one form to another. Thermodynamics helps us understand how energy is transformed and conserved in various systems, such as in the production of electricity or the functioning of a car engine.
  • General Engineering
  • Mechanical Engineering
11K
  • General Discussion
41K
