Analitical solution for dy/dt=ay^3+by^2+cy+d
  • Thread starter ced_the_jedi
In summary, the speaker is seeking help to find an analytical solution to the equation dy/dt=ay^3+by^2+cy+d, which can be simplified to ay^3+by^2+cy+d=0. They have attempted to solve it by finding the roots and integrating, but are struggling to find an explicit solution. Another person suggests solving a cubic equation for y, but notes that it may not be a straightforward process.
ced_the_jedi
Dear all
I have to solve an equation which seems to be simple:
It is dy/dt=ay^3+by^2+cy+d but my problem is that I am not able to give the analitical solution y(t)=... And I need your help for that...
What I have already done is :
- I know that you have to find the solutions of ay^3+by^2+cy+d=0 (the coefficients allow me to say that three solutions exist and lead to y1, y2 and y3 as real solutions)
- Then one can write :
dy/(ay^3+by^2+cy+d)=edy/(y-y1)+fdy/(y-y2)+gdy/(y-y3), with e, f, g easy to determine.
- Then you have to integrate on both sides of the equality : edy/(y-y1)+fdy/(y-y2)+gdy/(y-y3)=-dt
- which leads to something like that [(y-y1)^e][(y-y2)^f][(y-y3)^g]=exp(-t)
--> MY PROBLEM IS : do you know a way to express directly the analitical solution : y(t)=...? using this formulae, or by using a different integration method
I think you will get ##e^{+t}## on the right. To get an explicit solution instead of an implicit one, you need to solve a cubic equation for ##y##. That can be done but except for special cases, it isn't pretty.
I think it's worst than that. He has:
[tex](y-y_1)^a(y-y_2)^b(y-y_3)^c=e^t[/tex]
No way you're getting a y out of there unless you're desperate and plot the data then invert the data and fit it to a nice-size polynomial.
FAQ: Analitical solution for dy/dt=ay^3+by^2+cy+d
What is an analytical solution for dy/dt=ay^3+by^2+cy+d?
An analytical solution for this equation means finding a mathematical expression that represents the exact solution for the function y as a function of t. This means that we can plug in any value for t and get the corresponding value for y without needing to use numerical approximations.
How do you find the analytical solution for dy/dt=ay^3+by^2+cy+d?
To find the analytical solution, we need to use techniques such as separation of variables, integration, and solving for the constant of integration. This process can be complex and may require advanced mathematical skills.
Can you provide an example of an analytical solution for dy/dt=ay^3+by^2+cy+d?
Yes, for example, if we have the equation dy/dt=3y^3+2y^2+4y+1, the analytical solution would be y(t) = 1/(C - 2t - 2t^2 - t^3), where C is the constant of integration.
What are the advantages of using an analytical solution for dy/dt=ay^3+by^2+cy+d?
The main advantage of an analytical solution is that it provides an exact and precise solution without any approximation. This can be useful in many scientific fields where accuracy is crucial, such as in engineering, physics, and chemistry.
Are there any limitations to using an analytical solution for dy/dt=ay^3+by^2+cy+d?
Yes, there are some limitations to using an analytical solution. In some cases, it may not be possible to find an analytical solution, and numerical methods may be needed. Additionally, the process of finding the analytical solution can be complex and time-consuming, especially for more complicated equations.
