Math Amateur
MHB
- 3,998
- 48
I am reading several books on multivariable analysis/calculus and am trying to get a precise and rigorous theoretical understanding of implicit differentiation, including the Implicit Function Theorem ... in particular I am reading:
Vector Calculus (Second Edition) by Susan Colley
and
Calculus: Volume II (Second Edition) by Tom Apostol
I am trying to carefully relate the working in Apostol's first worked example in Section 9.7, just following Section 9.7 on the derivative of a function defined implicitly ... ... Worked Example 1 reads as follows:
View attachment 4041As indicated above, I have tried to work through this example carefully relating it to Colley's definition of the Chain Rule and also trying to be explicit about the structure of the functions involved ... Colley's statement of the Chain Rule is as follows:
https://www.physicsforums.com/attachments/4043
I have also tried to follow (very carefully) Apostol's analysis in Section 9.6 which reads as follows:
https://www.physicsforums.com/attachments/4044
I will now provide my analysis and would very much appreciate someone critiquing my analysis and point out any shortcomings, misinterpretations or errors ...We have \(\displaystyle g(x,y) = 0\) and \(\displaystyle y = Y(x)\) for all \(\displaystyle x\) in some open interval \(\displaystyle (a,b)\) ... and we let
\(\displaystyle G(x) = g[ x, Y(x)]\) for \(\displaystyle x \in (a,b)\) ... ...
Then ...
Following Apostol, Section 9.6 we put
\(\displaystyle u_1(x,y) = x\)
and
\(\displaystyle u_2(x,y) = y = Y(x)\)Then let \(\displaystyle G(x) = g[ u_1(x,y), u_2(x,y) ]\)
Let \(\displaystyle \underline{u} (x,y) = ( u_1, u_2)\)
So we have the situation as shown below in Figure 1.
So continuing ... for \(\displaystyle x \in (a,b)\) we have\(\displaystyle D(g \circ \underline{u} ) (x,y) = Dg (u_1, u_2) D \underline{u} (x,y) \)
or
... if we let \(\displaystyle h = g \circ \underline{u}\) then we have:
\(\displaystyle Dh (x,y) = Dg (u_1, u_2) D \underline{u} (x,y) \)
... ...Now we have that ...\(\displaystyle Dh (x,y) = \begin {bmatrix} \frac{ \partial h }{ \partial x} & \frac{ \partial h }{ \partial y} \end{bmatrix}
\)\(\displaystyle Dg (u_1, u_2) = \begin {bmatrix} \frac{ \partial g }{ \partial u_1} & \frac{ \partial gh }{ \partial u_2} \end{bmatrix}\)
and
\(\displaystyle D \underline{u} (x,y) = \begin {bmatrix} \frac{ \partial u_1 }{ \partial x} & \frac{ \partial u_1 }{ \partial y} \\ \frac{\partial u_2 }{ \partial x} & \frac{ \partial u_2 }{ \partial y} \end{bmatrix}\)Now
\(\displaystyle Dh (x,y) = Dg (u_1, u_2) D \underline{u} (x,y) \)That is\(\displaystyle \begin {bmatrix} \frac{ \partial h }{ \partial x} & \frac{ \partial h }{ \partial y} \end{bmatrix} = \begin {bmatrix} \frac{ \partial g }{ \partial u_1} & \frac{ \partial gh }{ \partial u_2} \end{bmatrix} \begin {bmatrix} \frac{ \partial u_1 }{ \partial x} & \frac{ \partial u_1 }{ \partial y} \\ \frac{\partial u_2 }{ \partial x} & \frac{ \partial u_2 }{ \partial y} \end{bmatrix}\) ... ... ... (1)
So then (1) gives\(\displaystyle \frac{ \partial h }{ \partial x} = \frac{ \partial g }{ \partial u_1} \frac{ \partial u_1 }{ \partial x} + \frac{ \partial g }{ \partial u_2} \frac{ \partial u_2 }{ \partial x}\)But ... ... since \(\displaystyle u_1(x,y) = x\) we can view \(\displaystyle \frac{ \partial g }{ \partial u_1}\) as \(\displaystyle \frac{ \partial g }{ \partial x}\)and we also have \(\displaystyle \frac{ \partial u_1 }{ \partial x} = 1 \)Further ...
... since \(\displaystyle u_2(x,y) = y = Y(x)\) we can write \(\displaystyle \frac{ \partial g }{ \partial u_2}\) as \(\displaystyle \frac{ \partial g }{ \partial y}\)and we also have \(\displaystyle \frac{ \partial u_2 }{ \partial x} = \frac{ \partial Y(x) }{ \partial x} = \frac{dY}{dx} = Y'(x)\) since \(\displaystyle Y\) is a function of \(\displaystyle x\) ...so
\(\displaystyle \frac{ \partial h }{ \partial x} = \frac{ \partial g }{ \partial x} \cdot 1 + \frac{ \partial g }{ \partial y} \cdot Y'(x)\) But ...
\(\displaystyle \frac{ \partial h }{ \partial x} = \frac{ \partial g[ u_1(x,y), u_2(x,y) ] }{ \partial x} = G'(x)\)
so we can write \(\displaystyle G'(x) = \frac{ \partial g }{ \partial x} \cdot 1 + \frac{ \partial g }{ \partial y} \cdot Y'(x) \)
and so we have
\(\displaystyle Y'(x) = - \ \frac{ \frac{ \partial g }{ \partial x} }{ \frac{ \partial g }{ \partial y} }\)I would be most grateful if someone could critique my analysis above and point out any shortcomings, misinterpretations or errors ... or just confirm the above analysis is OK ...
Peter
and
Then ...
and
or
and
and so we have
Peter
