Analysis of time-dependent SE (infinite square potential)
In summary: This is the same as the orthonormality of the wavefunction for a particle in a box, but it's not really related.
scorpion990
86
Hey all :)
I'm a second-semester junior who is studying chemistry and mathematics. I've self-studied basic quantum chemistry before, and I picked up Griffith's Introduction to Quantum Mechanics a few days ago to get a broader/more rigorous taste of the subject. I've been going through the reading/problems, and I'm really confused about something...
For those who want to follow along in the book, I'm referring to question 2.8 in the first edition.
Problem: Given [tex]\Psi(x,0)=Ax(a-x)[/tex] for a particle in a 1-dimensional box [tex](0<x<a)[/tex], find the time-dependent wave function for any given time.
Solution:
[tex]\Psi(x,t)=\sqrt\frac{2}{a}\sum^{\infty}_{n=1}c_n e^{\frac{-in^2 \pi^2 \hbar t}{2ma^2}}} sin\frac{n\pi x}{a}[/tex]
I found that:
[tex]c_n = \frac{\sqrt{60}}{a^3}\int^{a}_{0}x(a-x)sin\frac{n\pi x}{a}dx = \frac{8\sqrt{15}}{n^3\pi^3} [/tex]
... if n is odd. Its 0 if n is even.
Thus, the wavefunction is equal to:
[tex]\Psi(x,t)=\frac{4\sqrt{30}}{\pi^3n^3\sqrt{a}}\sum^{\infty}_{n=1}(1-(-1)^n)e^{\frac{-in^2 \pi^2 \hbar t}{2ma^2}}} sin\frac{n\pi x}{a}[/tex]
I know that I could rewrite that sum over just the odd integers. But it doesn't matter that much for now.
My questions are:
1. How can a particle in a box actually have such an initial wavefunction? I was under the impression that a particle in a box MUST have a wavefunction described by the simple sinusodidal waves that you get by solving the time-independent Schrodinger equation!
2. If a particle in a box can have any initial wavefunction, doesn't that mean that it can also have any initial energy? Where does the concept of quantization of energy come into play in this analysis?
3. Does the particle have a definite energy? How would I verify that its constant, as it should be?
Sorry for the confusion. Quantum chemistry books hardly ever cover time-dependence in quantum mechanics! I'm going to analyze my solution further. However, it's 4:40 AM and I should go to bed :)
Hey... Cool.
I just noticed that my solution and the orthonormality of the 1D particle in a box wavefunctions can be used to prove that:
[tex]\sum^{\infty}_{j=0}\frac{1}{(2j+1)^6}=\frac{\pi^6}{960}[/tex]
I have no idea what that has to do with quantum mechanics, but it sure is beautiful!
No. When [itex]\Psi[/itex] is a superposition of energy eigenfunctions:
[tex]\Psi = \sum {c_k \Psi_k}[/tex]
then if you measure the energy of the particle, you always get one of the discrete energy eigenvalues [itex]E_k[/itex], at random, with probablilties determined by the coefficients [itex]c_k[/itex]. Specifically, if [itex]\Psi[/itex] is normalized, then the probability of getting energy [itex]E_k[/itex] is [itex]|c_k|^2 = c_k^* c_k[/itex].
So is the particle's energy changing with time? Or is it constant but we are not able to know it absolutely due to the uncertainty principle?
There is no generally-agreed-upon answer to questions about what a QM particle is "really doing" before we measure its energy (or whatever other quantity). The mathematical formalism that you're learning simply doesn't address questions like these.
Most physicists, as a practical matter, probably would say that the exact value of the energy (and other quantities) is simply "undefined" before being measured, unless the particle is in an eigenstate of that quantity (e.g. in a specific "energy level" of the infinite square well). People have come up with various possible descriptions of what is "really" happening. We call these descriptions interpretations of QM. Unfortunately, there is (as yet) no way to distinguish among these interpretations experimentally, even in principle (so far as I know). It basically comes down to personal preferences.
Hmmm... I've read up on indeterminacy, interpretations, and wave-function collapse. I think what gets me is the fact that the potential energy of the particle is necessarily 0. It just seems strange to me that its energy wouldn't be known exactly, and that repeated measurements would give me different results.
See... I'm a chemist who hasn't really touched the time-dependent Schrodinger equation until now.
Hmmm... Thanks for the responses so far! I'd love to discuss this matter further if anybody wishes. Any comments, questions, answers would be appreciated!
scorpion990 said:
Hey... Cool.
This is not really quantum mechanics, or physics, for that matter. If you take a look at how the Riemann zeta function is calculated in terms of the Bernoulli numbers, then it uses a Fourier series which is a discrete sum, but the coefficients of this discrete Fourier series is calculated by an integral (the integral of the function). Going back and forth between discrete Fourier n-space and continuous x-space is what allows you to evaluate these things. For some reason integrals are easier than sums.
Otherwise you have to be conventional:
[tex]\zeta(6)=\frac{\pi^6}{945}=\frac{1}{1^6}+\frac{1}{2^6}+\frac{1}{3^6}+...=
(\frac{1}{1^6}+\frac{1}{3^6}+\frac{1}{5^6})
+\frac{1}{2^6}(\frac{1}{1^6}+\frac{1}{3^6}+\frac{1}{5^6})
+\frac{1}{4^{6}}(\frac{1}{1^6}+\frac{1}{3^6}+\frac{1}{5^6})
+\frac{1}{8^{6}}(\frac{1}{1^6}+\frac{1}{3^6}+\frac{1}{5^6})=
(\frac{1}{1^6}+\frac{1}{3^6}+\frac{1}{5^6}+...)(\frac{1}{1-\frac{1}{2^6}})[/tex]
scorpion990 said:
It just seems strange to me [...] that repeated measurements would give me different results.
When you measure a quantity, the system's wave function "collapses" into the eigenstate for whatever eigenvalue you get as the result of the measurement, and develops from there as time goes on. In your case, if you measure the energy of the particle in the box to be [itex]E_5[/itex], then immediately afterward [itex]\Psi = \Psi_5[/itex]. If nothing else interacts with the particle thereafter, it remains in that energy eigenstate.
FAQ: Analysis of time-dependent SE (infinite square potential)
1. What is the time-dependent Schrödinger equation (SE) in an infinite square potential?
The time-dependent Schrödinger equation is a fundamental equation in quantum mechanics that describes how the wave function of a quantum system evolves over time. In the case of an infinite square potential, the equation describes the behavior of a particle confined to a box with impenetrable walls.
2. How is the time-dependent SE solved in the case of an infinite square potential?
The solution to the time-dependent SE in the case of an infinite square potential involves separating the equation into two parts: one for the region inside the box and one for the region outside the box. The solution inside the box is a combination of sine and cosine functions, while the solution outside the box is a decaying exponential.
3. What is the significance of the eigenstates and eigenvalues in the analysis of time-dependent SE?
Eigenstates are the stationary states of a quantum system, which means that the wave function does not change over time. These states are important because they represent the possible energy levels of the system. Eigenvalues, on the other hand, represent the energy associated with each eigenstate. In the case of an infinite square potential, the eigenstates and eigenvalues correspond to the energy levels and energies of the particle confined in the box.
4. How does the time evolution of a quantum system in an infinite square potential differ from that in a finite potential?
In an infinite square potential, the particle is confined to a specific region and cannot escape, so its wave function remains confined within the box. In contrast, in a finite potential, the particle can move freely and its wave function can spread out over a larger region. This results in different solutions to the time-dependent SE and different behaviors of the particle over time.
5. What are some real-world applications of analyzing the time-dependent SE in an infinite square potential?
One example of a real-world application is the study of electrons in a semiconductor crystal, where the potential can be approximated as an infinite square potential. Understanding the behavior of electrons in this system is crucial for the development of electronic devices. Additionally, the time-dependent SE can also be applied to the study of chemical reactions and nuclear reactions, where the potential can be approximated as an infinite square well.
