Analysis Question-differentiabillity, continuity
In summary, the conversation discusses how to prove that for a continuously differentiable function f(x) satisfying f''(x)=-x^2f(x), there exists an a>0 such that f(a)=0. One approach is to show that f is also decreasing and crosses the x-axis before changing concavity and increasing. However, this approach is not necessarily true as demonstrated by a counterexample. Another approach is to prove by contradiction, assuming that f(x)>0 for all x>0 and showing that this leads to a contradiction.
JohnnyBG00d
Analysis Question--differentiabillity, continuity
Suppose [itex]f:\mathbb{R}\to\mathbb{R}[/itex] is a [itex]C^\infty[/itex] function which satisfies the equation [itex]f''(x)=-x^2f(x)[/itex] along with [itex]f(0)=1[/itex], [itex]f'(0)=0[/itex]. Prove that there is an [itex]a>0[/itex] such that [itex]f(a)=0[/itex]. Do not use any results from differential equations. Thank you.
Since f is continuously differentiable there is a [itex](0,\delta)[/itex] interval in which f is concave down. If we can show f is also decreasing then it follows that f must cross the x-axis before changing concavity and increasing because there can be no cusps as f is differentiable everywhere. I have no idea if that is the right track. Thank you.
Not true. A counterexample sin(x)+2 goes between convex and concave without crossing x.
Perhaps it'd be easier to prove by contradiction.
f(0)=1>0, by continuity, in the immediate neighborhood xE[0,c], f(x)>0. Let's (erroneously) assume f(x)>0 for all x>0. since f''(x)<0, f(x) concave down, it follows that
f(x)<f(c)+f'(c)(x-c) for all x>0 and c>0
You can prove f'(x)<0 for all x>0 (if the assumption is true), hence f'(x)=-|f'(x)|.
Now, let x=ζ=c+f(c)/|f'(c)|, it leads to
f(ζ)<0 where ζ>c>0. Now this contradicts with the assumption that f(x)>0 for all x>0.
Not pretty, just to bounce some idea.
FAQ: Analysis Question-differentiabillity, continuity
What is the definition of differentiability?
Differentiability is a property of a function where the function is smooth and the slope of the tangent line at each point on the function's graph is defined. In other words, the function must be continuous and have a defined derivative at each point.
How do you determine if a function is differentiable?
A function is differentiable if it meets the following criteria:
  1. The function is continuous at the point in question.
  2. The derivative of the function exists at the point in question.
  3. The derivative is defined as the limit of the slope of the secant line as it approaches the tangent line at the point in question.
What is the relationship between differentiability and continuity?
Continuity is a necessary but not sufficient condition for differentiability. This means that a function must be continuous in order to be differentiable, but just because a function is continuous does not mean it is automatically differentiable. Differentiability also requires that the function has a defined derivative at each point.
What is the difference between differentiability and smoothness?
Differentiability and smoothness are related concepts, but they are not the same. A function can be smooth without being differentiable. Smoothness refers to the overall shape and appearance of a function, while differentiability specifically refers to the existence of a derivative at each point.
Can a function be differentiable but not continuous?
No, a function must be continuous in order to be differentiable. This is because the existence of a derivative at a point depends on the function being continuous at that point. If a function is not continuous, it cannot have a defined derivative at that point.
