Analysis Riemann Integral problem
In summary: And therefore the supremums are also zero. In summary, the proof shows that the function f is Riemann integrable at alpha and that the Riemann-Stieltjes integral of f with respect to alpha is equal to zero.
fraggle
Suppose α(x) increases on [a,b] a≤ x_0 ≤b, α is continuous at x_0,
f(x_0) =1 , at all other x in [a,b] f(x)=0.
denote ('x knot' as x_0)
Prove that f is Riemann Integrable and that ∫fdα=0.
Can anyone check my proof or suggest a good method to show that inf U(P,f,α)= 0?
I have proved that the lower limit is equal to zero. Now I just need to prove that the upper limit is equal to zero or that f is Riemann Integrable.
Here's my attempt at proving that : U(P,f,α)= 0:
α continuous at x_0 ⇒ for each ε>0 there exists a δ>0 s.t for q in [a,b] if
⎮α(x_0)-α(q)⎮<ε then ⎮x_0 - q⎮<δ
Pick elements p<x_0<q in the neighborhood of radius δ about x_0 we can then choose a partition such that
Δα_i=(α(q)-α(p))/n
this is true for any segment (x_i-1,x_i) s.t ⎮x_i -x_0⎮<δ
Now choose a partition P of [a,b] with the above partition in the neighborhood of x_0 and arbitrarily let a=x_1 and b=b_2.
The definition of f(x) implies that the only segment of the partition P where Σsupf(x) is not equal to zero is a segment in the neighborhood of radius δ about x_0.
There supf(x)=1
so Σsupf(x)Δα_i = (α(q) -α(p))/n
This being true for all n in N we can take n very large to get zero.
Does this work?
If not can anyone give a hint?
Thank you
Actually I think I may have found a different proof:
From the definition of f it can be shown that f is continuous at every point in [a,b] except for x_0. Therefore f is discontinuous at only finitely many points in [a,b].
Again from the definition f is bounded.
alpha is given to be continuous at x_0.
Therefore by (theorem 6.10 in Rudin) f is Riemann integrable at alpha. (1)
The lower Riemann integral of f is equal to zero (easily proved). (2)
Therefore by (1) and (2) the total Riemann integral of f in [a,b] is equal to zero.
There is no "f" in the statement of your problem! Do you mean "a"?
There is no "alpha" in the statement of your problem!
What does "at alpha" mean? Is alpha a function or a point?
The f is the f(x) defined in the statement. Sorry if that was not clear.
I used the greek letter alpha "α" in the statement of the problem. I see that the font is kind of ambiguous.
Both f and alpha "α" are functions defined on [a,b].
I would probably just use a five point partition P_n consisting only of a, r_n, x_0, s_n, and b, where r_n=x_0 - 1/n, and s_n=x_0 + 1/n. Then write out the upper sum U(P_n,f,alpha). Then let n approach infinity.
But in the intervals [a,r_n] and [s_n,b] as n approaches infinity r_n and s_n approach x_0. Then we could take f(x_0) as supf(x) in those intervals, that is if n goes to infinity.
So wouldn't the sum be equal to 2?
If that is not the case could you please explain?
thanks
thanks
No, because on those two intervals f is identically zero.
FAQ: Analysis Riemann Integral problem
What is the Riemann integral?
The Riemann integral is a method of computing the area under a curve on a given interval. It is used to evaluate the definite integral of a function by dividing the interval into smaller subintervals and approximating the area using rectangles.
What is the difference between the Riemann integral and the Lebesgue integral?
The Riemann integral is based on partitioning the interval into smaller subintervals, while the Lebesgue integral is based on partitioning the range of values of the function. This makes the Lebesgue integral more general and allows for the integration of a wider class of functions.
What is the significance of the Riemann integral in calculus?
The Riemann integral is a fundamental concept in calculus and is used to solve many problems in science and engineering. It allows for the calculation of areas, volumes, and other quantities that are important in many real-world applications.
What is the definition of a Riemann integrable function?
A function is Riemann integrable if it is continuous on a closed interval and has a finite number of discontinuities. It must also be bounded on the interval, meaning that its values do not exceed a certain limit.
What are some techniques for solving Riemann integral problems?
There are several techniques for solving Riemann integral problems, including the use of partitioning, the midpoint rule, and the trapezoidal rule. Additionally, the fundamental theorem of calculus and substitution can be used to evaluate Riemann integrals.
