Analytic Geometry / Vectors - Finding an Angle Bissector
In summary, to find the vector, parametric, and symmetric equations of the angle bissector of angle ∠ABC, given points A=(1,2,3), B=(3,4,5), and C=(6,7,0), one can define a point D=(d_1,d_2,d_3) in the bissector and two lines r and s using points A and B and B and C respectively. The distance between D and r must be equal to the distance between D and s, and D can be expressed as D=(3-2m+3n,4-2m+3n,5-2m-5n) for some m and n. Normalizing the direction
B.Cantarelli
Question:
What are the vector, parametric and symmetric equations of the angle bissector of angle ∠ABC, given that A=(1,2,3), B=(3,4,5) and C=(6,7,0).
Attempt at resolution:
Well, I defined some D=(d_1,d_2,d_3) to be a point in the angle bissector, and two lines r:X=(3+2a,4+2a,5+2a) and s:Y=(3+3b,4+3b,5-5b) for any a,b, which are the lines defined by points A and B and B and C respectively.
So, I realize that the distance between D and r must be the same as the distance between D and s, and that D=(d_1,d_2,d_3)=(3-2m+3n,4-2m+3n,5-2m-5n) for some m and n. The problem is that I do not seem to be able to find some efficient way to solve for these restrictions.
Normalize the direction vectors for the two lines. In other words, if you can find a point D on BA that's one unit away from B and a point E on BC that's one unit away from B, then F=(D+E)/2 will be on the bisector, right? Once you have have a single point on the bisector that's not B, you can find its equation.
Oh, of course. Thank you very much Dick.
Related to Analytic Geometry / Vectors - Finding an Angle Bissector
1. What is analytic geometry and how is it related to finding an angle bisector?
Analytic geometry is a branch of mathematics that involves using algebraic equations to study geometric shapes and properties. It is related to finding an angle bisector because it uses equations and coordinates to determine the location and properties of the angle bisector.
2. How do you find the equation of an angle bisector using analytic geometry?
To find the equation of an angle bisector using analytic geometry, you need to first find the slope of the two lines that form the angle. Then, use the midpoint formula to find the coordinates of the midpoint of the angle. Finally, use the slope formula to find the slope of the angle bisector and use it to write the equation in slope-intercept form.
3. Can you find the angle bisector of a triangle using analytic geometry?
Yes, you can find the angle bisector of a triangle using analytic geometry. To do so, you will need to use the coordinates of the vertices of the triangle and follow the same steps as finding the equation of an angle bisector. However, you will need to find the slopes of two of the sides of the triangle and use the angle bisector theorem to find the slope of the angle bisector.
4. What is the angle bisector theorem and how is it used in analytic geometry?
The angle bisector theorem states that the angle bisector of an angle in a triangle divides the opposite side into segments that are proportional to the other two sides of the triangle. In analytic geometry, this theorem is used to find the slope of the angle bisector when finding the equation of the angle bisector of a triangle.
5. Are there any real-world applications of finding an angle bisector using analytic geometry?
Yes, there are many real-world applications of finding an angle bisector using analytic geometry. Some examples include using it in navigation and surveying to determine the shortest distance between two points, in engineering and architecture to design structures with equal angles, and in physics to calculate the direction of forces acting on an object.
  • Science and Math Textbooks
