Analytic solution of the Earth's orbit around the Sun
In summary, the conversation is about comparing numerical and analytical solutions for a code that calculates the motion of the Earth and the Sun. The code uses the gravity constant, masses of the Sun and Earth, and various parameters to calculate the position and velocity of each object over time. The person is seeking help understanding the use of the equation for calculating the distance between the Sun and Earth, and how to incorporate the center of mass into the calculations. They also mention that the code can be improved, but it currently works.
Nasa123123
Find the analytical solution of earths orbit around the sun, the sun is centered in origo. Include the pull from earth on the sun, and sun on the earth.
We know that
mass of earth = 5.972*10^24 kg
mass of sun = 1.989*10^30 kg
G = 6.67 * 10^-11 Nm^2/kg^2
distance at aphelion = 1.521*10^11 m
velocity (only in y-direction at aphelion) = 29290 m/s
F = - G*m1*m2/r^2
The exercise is to compare numerical and analytical solution. I have worked out the code from earlier exercise (see code under this text), but I don't understand how the analytical solution works. I have tried to use the equation r(theta) = a(1-e^2)/(1+e*cos(theta)), which is OK but I don't think this is how we are supposed to do it. I think we are supposed to do some calculations with the center of mass but I just don't understand it.
Ps. I know my code probably can be more efficient with two dimensional arrays etc, but it works so I am just asking for help with the problem.
Numerical solution:
from numpy import *
import matplotlib.pyplot as plt
G = 6.67E-11            # Gravity constant
m_s = 1.989E30          # Mass of sun
m_e = 5.972E24          # Mass of earth
t = 60*60*24*365*2
dt = 60*60*12
n = int(t/dt)
t = zeros(n)
x_sun = zeros(n, float)
y_sun = zeros(n, float)
x_earth = zeros(n, float)
y_earth = zeros(n, float)
vx_sun = zeros(n, float)
vy_sun = zeros(n, float)
vx_earth = zeros(n, float)
vy_earth = zeros(n, float)
radius = zeros(n, float)        # Distance sun and earth
rx = zeros(n, float)            # r-vector x
ry = zeros(n, float)            # r-vector y
x_earth[0] = 1.521E11     # Start position x-coordinate
y_earth[0] = 0
x_sun[0] = 0
y_sun[0] = 0
vx_earth[0] = 0
vy_earth[0] = 29290       # Start velocity, y-coordinate Earth at aphelion
vx_sun[0] = 0             # Sun centered at origo
vy_sun[0] = 0for i in range(n-1):
    rx[i] = x_earth[i] - x_sun[i]               # x-coordinates r-vector
    ry[i] = y_earth[i] - y_sun[i]               # y-coordinates r-vector
    r_v = (rx[i], ry[i])                        # r-vector
    radius[i] = linalg.norm(r_v)                # Length r-vector
    F_x = ((-G*m_s*m_e)/radius[i]**3) * rx[i]     # Forces x-direction
    F_y = ((-G*m_s*m_e)/radius[i]**3) * ry[i]     # Forces y-direction
    ax_e = F_x/m_e      # Acceleration x-direction, Earth on sun
    ay_e = F_y/m_e      # Acceleration y-direction, Earth on sun
    ax_s = -F_x/m_s     # Acceleration x-direction, sun on earth
    ay_s = -F_y/m_s     # Acceleration y-direction, sun on earth
    vx_sun[i+1] = vx_sun[i] + ax_s*dt       # Velocity, sun
    vy_sun[i+1] = vy_sun[i] + ay_s*dt       # Velocity, sun
    vx_earth[i+1] = vx_earth[i] + ax_e*dt   # Velocity, earth
    vy_earth[i+1] = vy_earth[i] + ay_e*dt   # Velocity, earth
    x_sun[i+1] = x_sun[i] + vx_sun[i+1]*dt  # x-coordinate, sun
    y_sun[i+1] = y_sun[i] + vy_sun[i+1]*dt  # y-coordinate, sun
    x_earth[i+1] = x_earth[i] + vx_earth[i+1]*dt  # x-coordinate, earth
    y_earth[i+1] = y_earth[i] + vy_earth[i+1]*dt  # y-coordinate, earth
    t[i+1] = t[i] + dt       # Update timeplt.plot(x_earth, y_earth)
plt.plot(x_sun, y_sun)
plt.show()
The Sun can't stay at the origin in an inertial reference frame. With your starting parameters the whole system will translate and move away from the origin over time. Putting the origin at the center of mass is much, much more useful.
Related to Analytic solution of the Earth's orbit around the Sun
1. What is an analytic solution?
An analytic solution is a mathematical expression that can be used to describe a physical phenomenon or system. In the case of the Earth's orbit around the Sun, it is a mathematical model that can predict the position of the Earth at any given time.
2. How is the Earth's orbit around the Sun calculated?
The Earth's orbit around the Sun is calculated using Newton's laws of motion and gravitation. This involves taking into account the mass and distance of the Earth and the Sun, as well as the gravitational force between them.
3. Why is an analytic solution important for studying the Earth's orbit?
An analytic solution allows scientists to accurately predict the position of the Earth at any given time, which is crucial for understanding and studying the Earth's orbit. It also provides a basis for further analysis and can help scientists make predictions about future changes in the Earth's orbit.
4. How accurate is the analytic solution of the Earth's orbit?
The analytic solution of the Earth's orbit is very accurate, as it takes into account all the major factors that influence the Earth's orbit, such as gravity and the mass and distance of the Earth and Sun. However, it is important to note that there are small variations in the Earth's orbit due to other factors, such as the gravitational pull of other planets.
5. Can the analytic solution be used to predict the Earth's orbit in the distant future?
Yes, the analytic solution can be used to predict the Earth's orbit in the distant future. However, as mentioned before, there are factors that can cause small variations in the Earth's orbit, so the predictions may not be completely accurate. Additionally, as time goes on, the Earth's orbit may be influenced by other factors that are currently unknown, making it difficult to make accurate long-term predictions.
  • Astronomy and Astrophysics
