Analytical chemistry solutions
In summary, in polynomial equations with multiple roots in a system of equilibria, the correct solution can be determined by selecting the smallest real, positive root. This rule works in most cases, including when solving for extent or concentration in complicated systems. However, in some cases, such as when there are multiple solutions with physical sense, or when there are other restrictions on the concentrations, this rule may not apply. In those cases, taking all restrictions into account can help in choosing the correct root.
Big-Daddy
343
If a polynomial equation is solved for multiple roots in a system of equilibria (e.g. calculating extent of a reaction, or solving for [H+] in a complicated acid-base system, to give two basic examples) how do we know which, among the roots, is the correct solution (e.g. the correct extent or the correct proton concentration for the two cases above)?
Is it always (in analytical chemistry/equilibrium situations) the smallest real, positive root which is the one we should take? We can assume the root which correctly represents the solution must be real and positive (and often, smaller than a certain upper limit we can impose, as e.g. in the case of extent) but must it be the smallest, and if not, how do we choose the correct root?
Chemistry news on Phys.org
So far I have never seen a system form which there will be more than one solution having physical sense.
Neither extent, nor when solving for a concentration? Well you would know... it's surprising that this would be the case even for complicated systems, 8,9,10 degree polynomials etc.
So in your experience does the "smallest real positive root" 'rule' always work, or when will it not be physically acceptable? Of course in extent there will only be an upper limit (=number of moles of limiting reagent / stoichiometric coefficient of reagent), lower limit is 0. any situation where this rule doesn't work, off the top of your head?
In all these cases you are solving a system of equations for various concentrations, not just one. All these concentrations are restricted to be positive and eventually there are other restrictions, too. If you take them all into account you will select the correct root of the equation.
As a scientist in the field of analytical chemistry, I can provide some insight into this question. When solving for multiple roots in a system of equilibria, it is important to consider the physical and chemical context of the problem. In most cases, the correct solution will be the smallest real, positive root. This is because equilibrium systems tend to favor the lowest energy state, which is represented by the smallest root.
However, there may be cases where the smallest root does not accurately represent the solution. This could occur if there are other factors at play, such as a highly concentrated reactant or product that may shift the equilibrium. In these cases, it is important to carefully consider the experimental conditions and any potential sources of error.
Additionally, in some cases, it may be necessary to impose an upper limit on the root in order to accurately represent the solution. This could be due to limitations in the experimental setup or the physical properties of the system.
In conclusion, while the smallest real, positive root is often the correct solution in analytical chemistry and equilibrium situations, it is important to carefully consider all factors and context in order to accurately determine the correct root.
Related to Analytical chemistry solutions
What is analytical chemistry?
Analytical chemistry is a branch of chemistry that deals with the identification, quantification, and separation of chemical compounds in various samples. It involves using various techniques and instruments to analyze the chemical makeup of a substance.
What are some common solutions used in analytical chemistry?
Some common solutions used in analytical chemistry include acids, bases, buffers, and solvents. These solutions are used to prepare samples for analysis, adjust pH levels, and dissolve various compounds.
How are analytical chemistry solutions made?
Analytical chemistry solutions are typically made by accurately measuring out specific amounts of solutes and dissolving them in a solvent. The concentration of the resulting solution can be adjusted by adding more solute or solvent as needed.
What are the benefits of using analytical chemistry solutions?
Using analytical chemistry solutions allows for precise and accurate measurements of chemical compounds in samples. This information is crucial in fields such as pharmaceuticals, environmental science, and forensics.
How do analytical chemistry solutions differ from other types of solutions?
Analytical chemistry solutions are specifically designed and prepared for use in chemical analysis. They often have very precise concentrations and may contain specific additives to enhance the accuracy and sensitivity of the analysis.
  • Mechanical Engineering
  • General Math
  • Linear and Abstract Algebra
