A Analytical expression of Cosmic Variance - Poisson distribution?
The discussion focuses on computing the Cosmic Variance term, denoted as ##N^{C}##, within the context of the Matter Angular power spectrum. The user has developed a numerical method for the angular power spectrum but lacks an explicit expression for Cosmic Variance. They inquire whether the relation ##\dfrac{\sigma_{p}}{P}=\dfrac{2}{N_{k}^{1/2}}## can be interpreted as a Signal Noise Ratio. A suggestion is made to refer to Wikipedia for Sample Variance and a specific paper that addresses uncertainty due to restricted sample size. The conversation emphasizes the need for a clear understanding of Cosmic Variance in the user's computations.
fab13
TL;DR Summary
I would like to get an analytical expression of Cosmic Variance to be able to compute the Matter Angular Power Spectrum (including theorical signal and spectroscopic Shot Noise). I suspect this Cosmic variane to look like a Poisson distribution but I can't conclude with this up to now.
I have an expression of Matter Angular power spectrum which can be computed numerically by a simple rectangular integration method (see below). I make appear in this expression the spectroscopic bias ##b_{s p}^{2}## and the Cosmic variance ##N^{C}##.
\begin{aligned}
\mathcal{D}_{\mathrm{gal}, \mathrm{sp}} &=\left[\int_{l_{m i n}}^{l_{\max }} C_{\ell, \mathrm{gal}, \mathrm{sp}}(\ell) \mathrm{d} \ell\right]=b_{s p}^{2}\left[\int_{l_{\min }}^{l_{\max }} C_{\ell, \mathrm{DM}} \mathrm{d} \ell+N^{C}\right]=b_{s p}^{2}\left[\mathcal{D}_{\mathrm{DM}}+N^{C}\right] \\ & \simeq \Delta \ell \sum_{i=1}^{n} C_{\ell, \mathrm{gal}, \mathrm{sp}}\left(\ell_{i}\right)
\end{aligned}
I have a code that computes the terms ##C_{\ell, \mathrm{gal}, \mathrm{sp}}\left(\ell_{i}\right)## for each multipole ##\ell_{i}##. But how to compute the term ##N^{C}##, that is to say, the Cosmic Variance ##N^{C}## :
The only documentation I have found is the following slide from Nico Hamaus :
But as you can see, I have no explicit expression for Cosmic Variance : Could I consider the relation ##\dfrac{\sigma_{p}}{P}=\dfrac{2}{N_{k}^{1/2}}## as a SNR (Signal Noise Ratio) ?
Which expression of Cosmic Variance could I use to compute the whole expression ##\mathcal{D}_{\mathrm{gal}, \mathrm{sp}}## ?
Thanks in advance, Best regards
Space news on Phys.org
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
