Analytical solution for circular cavity under internal pressure
In summary, there are several resources available that discuss the analytical solution for stress and displacements in an infinite circular cavity under internal pressure, but further research may be needed to find a direct connection to Timoshenko's theory of elasticity.
roger1318
A book listed the problem infinite circular cavity under internal pressure and said there is a analytical solution for stress and displacements but it didn't give any reference.
I have searched many papers and online materials but still couldn't find anything.
The closest thing I found in Timoshenko's theory of elasticity book is the analytical solution for cylinder under uniform inner and outer pressure modeled as a plain strain problem.
I am wondering if there is connection between the two problems, and if not, could anyone give some hints or reference?
Thanks very much
!Unfortunately, it is difficult to answer this question without more information about the book or the specific problem you are trying to solve. However, there have been several studies published on the subject of infinite circular cavities under internal pressure. One example is a 1995 paper by B.J. Everett and G.H. Paulino titled "Analytical Solution for the Stress-Strain State in an Infinite Circular Cavity Under Internal Pressure" which can be found in the International Journal of Solids and Structures. It provides an analytical solution for the stress-strain state in an infinite circular cavity under an internally applied pressure. Other papers that may provide additional insight include "Analytical Solutions for the Stress-Strain State in an Infinite Circular Cavity Under Internally Applied Pressure" (2003) and "Analysis of an Infinite Circular Cavity Under Internal Pressure Using the Finite Element Method" (2011).
FAQ: Analytical solution for circular cavity under internal pressure
What is an analytical solution for circular cavity under internal pressure?
An analytical solution for circular cavity under internal pressure is a mathematical solution that can be derived to accurately predict the stress and deformation of a circular cavity when it is subjected to internal pressure. This solution is derived using mathematical equations and can be used to analyze the behavior of circular cavities in various engineering applications.
Why is an analytical solution for circular cavity under internal pressure important?
An analytical solution for circular cavity under internal pressure is important because it provides a quick and accurate method to predict the behavior of a circular cavity subjected to internal pressure. This solution can be used to design and analyze various structures such as pressure vessels, pipes, and containers.
What factors affect the accuracy of an analytical solution for circular cavity under internal pressure?
The accuracy of an analytical solution for circular cavity under internal pressure depends on various factors such as the assumptions made in the derivation of the solution, the material properties of the cavity, and the boundary conditions. In some cases, the solution may need to be verified and validated using experimental data to ensure its accuracy.
What are the limitations of an analytical solution for circular cavity under internal pressure?
One limitation of an analytical solution for circular cavity under internal pressure is that it may not be applicable to complex geometries or cases where the material properties are not uniform. Additionally, the solution may not take into account factors such as stress concentrations or the influence of external loads. In these cases, numerical methods may be more appropriate for analysis.
How can an analytical solution for circular cavity under internal pressure be used in engineering applications?
An analytical solution for circular cavity under internal pressure can be used in engineering applications to design and analyze structures such as pressure vessels, pipes, and containers. It can also be used to determine the critical internal pressure that a cavity can withstand before failure. This solution can help engineers make informed decisions and ensure the safety and reliability of their designs.
