Analyzing Elastic Collisions
In summary, the relative velocities before and after a collision between two particles in an elastic interaction will be the same, regardless of the reference frames chosen.
gibberingmouther
120
"For a two-particle interaction, the relative velocity between the two vectors is independent of the choice of relatively inertial reference frames."
and
"The change in kinetic energy is independent of the choice of relatively inertial reference frames."
My textbook says that if you look at the velocities of a two particle elastic interaction before and after the collision, regardless of which reference frame you choose, the relative velocities before and after will be the same. It just says this, and I guess expects you to make an intuitive leap? I wanted a more mathematical explanation which is why i looked on the internet and found the MIT page. The professor gives an example in the case of a two particle interaction where the one particle is twice the mass of the other, and shows that in this case the relative velocities will be the same. Cool, but i wasn't really satisfied.
Anyway, besides hoping for a better explanation of the relative velocities in an elastic collision, I was also confused by the terminology of "a relatively inertial reference frame". I want to read and understand the MIT pdf but i need to be able to know what that terminology means first. I am also hoping someone could help me by explaining the two statements from the pdf i quoted above.
http://web.mit.edu/8.01t/www/materials/modules/chapter15.pdf
conservation of kinetic energy and conservation of momentum.
i tried to imagine two coordinate systems moving relative to each other and the velocities being different while the relative velocities are the same. couldn't quite manage it. maybe i should drink more coffee, lol? I'm grateful for my intelligence but I'm not quite an Einstein :(
i was able to read some of the math in the MIT pdf but still trudging through, just need to get unstuck on the parts i mentioned above.
If in the first frame the velocities are ##\vec u_1## for particle 1 and ##\vec u_2## for particle 2, what is the velocity of particle 2 relative to particle 1 in that frame?
If a second frame has velocity ##\vec f## relative to the first frame, what is the velocity of particle 1 in that frame?
Likewise, particle 2 in the second frame?
I believe that means the frames are not accelerating relative to each other. So they need not be inertial franes, but whatever acceleration they have is the same for each.
Likes gibberingmouther
The easiest way of seeing that the relative velocity must remain the same after the collision is to go to the centre of mass frame where the total momentum is zero. This means that both objects must have momenta that are equal in magnitude but opposite in direction.
It looks like you have actually several questions here.
1) It might be a good exercise to show that if momentum is conserved in one inertial frame of reference, then it is conserved in all inertial frames of reference.
Hint: use the idea @haruspex gave you above for 3D motion.
2) Then, you might like to show that if momentum is conserved, then the change in kinetic energy is the same in all inertial reference frames.
Hint: try the case of 1D motion first and then extrapolate to 3D.
The above is true for any interaction of two or more particles.
3) A collision of two particles is elastic if kinetic energy is conserved, which is equivalent to the separation speed between the particles being the same before and after the collision.
Again, it's a good exercise to show this. Hint: see @Orodruin 's post.
The maths is there on page 15_6 of your very excellent reference.
Related to Analyzing Elastic Collisions
1. What is an elastic collision?
An elastic collision is a type of collision in which kinetic energy is conserved. This means that the total kinetic energy before the collision is equal to the total kinetic energy after the collision. In an elastic collision, there is no loss of energy due to friction or deformation of the objects involved.
2. How do you analyze elastic collisions?
To analyze an elastic collision, you need to use the principles of conservation of momentum and conservation of kinetic energy. This involves setting up equations to calculate the velocities of the objects before and after the collision, and solving for the unknown variables.
3. What is the difference between elastic and inelastic collisions?
The main difference between elastic and inelastic collisions is that inelastic collisions do not conserve kinetic energy. This means that the total kinetic energy after the collision is less than the total kinetic energy before the collision. In inelastic collisions, some of the energy is lost as heat or sound due to friction or deformation of the objects involved.
4. Can an elastic collision occur between objects of different masses?
Yes, an elastic collision can occur between objects of different masses. The conservation of momentum and kinetic energy principles still apply, but the velocities of the objects after the collision will be different depending on their masses.
5. What are some real-life examples of elastic collisions?
Some real-life examples of elastic collisions include billiard balls colliding on a pool table, a rubber ball bouncing off a hard surface, and two air molecules colliding in the atmosphere. In each of these cases, the objects involved do not experience any permanent deformation, and their total kinetic energy is conserved.
