Analyzing panel indicator bulbs in accident investigations
  • Thread starter Thread starter anorlunda
    Accident
Analyzing panel indicator bulbs in accident investigations involves examining the filaments of incandescent bulbs to determine which warnings were active at the time of impact. Hot filaments are believed to be more brittle and likely to break upon collision, while cold filaments may retain their coiled shape. This method has historical precedent, such as a case in Poland where filament analysis was used to investigate a police car accident. However, doubts remain about the reliability of this technique as a dependable investigative tool. Overall, while the method has been discussed, its effectiveness in court remains questionable.
anorlunda
Staff Emeritus
Insights Author
At 19:00 of the video below, an investigator makes the statement.
"also if you have some indication panels for example with bulbs in it, you can after a crash, you can analyze the different wires in the bulbs and then you can determine which for example indications or even warnings were active at the moment of impact."
Langauge may be a factor here. By wires, I assume he means the filaments of incandescent bulbs. Not the signal or power wires leading to the bulb.
I can imagine that a hot filament is more brittle and likely to break on impact than a cold one. But I have a hard time believing that this is a dependable method of accident investigation.
Has anyone else heard of this method? What about auto accident investigations? Has this ever been used as evidence in court?
I heard of this many years ago - I think it an old idea and used by police to find out if a car had its lights switched on in an accident.
Many years ago there was definitely such a case in Poland, police car going without lights caused an accident and state of filaments was one of the things checked during the forensic investigation (sadly, police and attorneys did everything to cover the case and to accuse people reporting that car had no lights on of false reports/statements).
A hot filament is stretched by the deceleration to form a large loop.
A cold filament may break away from the supports, but fragments will remain tightly coiled.
If the glass envelope breaks while the filament is hot, it will immediately oxidise.
Likes Klystron, Borek, Tom.G and 1 other person
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
10K
10K
502K
10K
