Analyzing the Force of Two Disk Magnets on a Metal Plate
Two disk magnets are positioned with their north poles facing each other, creating a repulsive force while a metal plate is fixed to rotate between them. The magnetic fields do not connect directly; instead, they bend outwards, resulting in a plane of symmetry where the magnetic field strength is effectively zero. When the metal plate is placed between the magnets, the magnetic field lines pass through the metal, but the forces from the magnets do not cancel out, as there is no field in that central area. The pull on the metal plate is less than the force needed to rotate it out of position, confirming that the magnets' repulsion is dominant. Understanding this interaction clarifies the dynamics of magnetic forces in this setup.
Kupa140
The situation is as follows. We have two disk magnets. One is fixed on the ground, table, or surface and has the north pole facing up. Then we have a metal plate fixed on the vertical axis rod or something similar such that it can't move up or down, but only rotate horizontally with as less friction as possible. The metal piece is slightly above the surface of the first magnet and the magnet will obviously attract it.
We also have right above the first magnet and the needed space for the metal piece a fixed cylindrical tube holding the second identical magnet inside it, and it also allows the second magnet to slide up and down within the tube. The magnets are facing each other with the same poles, so north north. With nothing between the magnets, the second one would float above the first magnet with a given distance calculated by their repulsive force and so on.
Now to the question, the metal piece now rotates such that it's between the two magnets and the magnetic filed lines will now pass through the metal instead of air, the second one will fall lower than it's previous position and both will be attracted to the metal, would their force on the metal cancel each other out? If not, is their pull on the metal greater or lower than the necessary force needed to rotate the metal piece out of the position between them? My assumption is that a great deal is perpendicular on the metal and since the metal piece is fixed it should be less.
Welcome to PF.
There will be a plane of symmetry between the two north poles where there is no field. The two magnetic fields do not connect and flow through the two magnets, they bend out sideways and so avoid each other.
Kupa140 said:
Now to the question, the metal piece now rotates such that it's between the two magnets and the magnetic filed lines will now pass through the metal instead of air, ...
There is no field halfway between the magnets where you place the metal plate.
Baluncore said:
Welcome to PF.There will be a plane of symmetry between the two north poles where there is no field. The two magnetic fields do not connect and flow through the two magnets, they bend out sideways and so avoid each other.There is no field halfway between the magnets where you place the metal plate.
It took me a while but now i understand, thank you.
Likes hutchphd and berkeman
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 17 ·
15K
