MHB Andrew's question at Yahoo Answers (Similar matrices)
  • Thread starter Thread starter Fernando Revilla
    Matrices
The discussion revolves around finding a diagonal matrix C and an invertible matrix B such that the matrix A can be expressed as A = BCB^-1. The characteristic polynomial of A is determined to be (1-λ)(λ+1)(λ-3), revealing the eigenvalues 1, -1, and 3, which confirms that A is diagonalizable. The eigenspaces corresponding to these eigenvalues are identified, leading to the construction of matrices B and C. Specifically, B is given as a matrix formed from the eigenvectors, and C is the diagonal matrix containing the eigenvalues. The relationship A = BCB^-1 can be verified by checking the equivalent equation AB = BC.
Fernando Revilla
MHB
Here is the question:
Let A =
7 -8 0
4 -5 0
-1 1 1
If possible, find a diagonal matrix C and an invertible matrix B such that A = BCB^-1
I have found the characteristic polynomial of A, along with the eigenvalues/vectors. However I just don't understand this question, and my notes/textbook is completely useless! I assume the two matrices A and C will be similar, thus have the same eigenvalues. But how am I supposed to show that matrix!?
Here is a link to the question:
Question on Similar Matrices? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello Andrew,
The characteristic polynomial of $A$ is: $$\begin{aligned}\chi (\lambda)&=\begin{vmatrix}{7-\lambda}&{-8}&{0}\\{4}&{-5-\lambda}&{0}\\{-1}&{1}&{1-\lambda}\end{vmatrix}\\&=(1-\lambda)\begin{vmatrix}{7-\lambda}&{-8}\\{4}&{-5-\lambda}\end{vmatrix}\\&=(1-\lambda)(\lambda+1)(\lambda-3)\end{aligned}$$ The eigenvalues are $1,-1,3$ (all simple) and according to a well-known property, the matrix is diagonalizable. The eigenspaces (with corresponding basis) are: $$V_1\equiv\left \{ \begin{matrix}6x_1-8x_2=0\\4x_1-6x_2=0\\-x_1+x_2=0\end{matrix}\right.\qquad B_{V_1}=\{(0,0,1)\}$$ $$V_{-1}\equiv\left \{ \begin{matrix}8x_1-8x_2=0\\4x_1-4x_2=0\\-x_1-x_2+2x_3=0\end{matrix}\right.\qquad B_{V_{-1}}=\{(1,1,1)\}$$ $$V_3\equiv\left \{ \begin{matrix}4x_1-8x_2=0\\4x_1-8x_2=0\\-x_1-x_2-2x_3=0\end{matrix}\right.\qquad B_{V_3}=\{(4,2,-1)\}$$ So, if $$B=\begin{bmatrix}{0}&{1}&{\;\;4}\\{0}&{1}&{\;\;2}\\{1}&{1}&{-1}\end{bmatrix}\;,\quad C=\begin{bmatrix}{1}&{\;\;0}&{0}\\{0}&{-1}&{0}\\{0}&{\;\;0}&{3}\end{bmatrix}$$ then, $A=BCB^{-1}$. You can easily verify this equality proving the equivalent one $AB=BC$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
