Android Tablet adb shell command Questions
In summary: Additionally, if you want to test your app on a specific device, you can use a virtual machine to simulate that device's display size. In summary, if you're having problems with adjusting the display size and density on your device, try using an emulator or a virtual machine to test your app on different display sizes. This will save you time and hassle compared to constantly restarting your device.
whitehorsey
192
I've been testing out the adb shell am display-size and adb shell am display-density on my 10 inch tablet using the command prompt. The adb shell am display-density is considered an unrecognized command while adb shell am display-size, I was able to change the display size to 800x500 but not to 1280x800 (7 inch display size?). I want to test an Android app I created on a 7 inch display size. Also, the three buttons on the bottom where the home/back key is disappears. They won't reappear even when I do adb shell am display-size reset. The only way to get the keys back are by restarting the whole system. How can I fix these problems?
Technology news on Phys.org
There are a few ways to fix these problems. First, you can try using a different command to adjust the display size. For example, you can use the 'wm size' command instead of the 'am display-size' command. This command should also allow you to adjust the display size to 1280x800. Second, you can try using an emulator such as Genymotion or BlueStacks. These emulators allow you to simulate a device with a 7-inch display size and will not require you to use any commands to adjust the display size. Finally, you can try using a virtual machine such as VirtualBox. This will allow you to run an operating system on your computer which has a 7-inch display size. You will be able to test your app in this environment without having to restart the whole system.
The best way to fix these problems is to use an emulator. An emulator allows you to simulate different display sizes and densities on your computer so that you can test out your app on different screen sizes and densities. This way, you don't need to reset your device every time you want to test out a different display size or density. You can find many free emulators online such as Genymotion, Android Studio's emulator, and Bluestack.
FAQ: Android Tablet adb shell command Questions
What is the adb shell command for Android tablets?
The adb shell command for Android tablets is used to access the Android Debug Bridge (ADB) shell, which allows you to communicate with an Android device connected to your computer via USB. This command is mainly used for debugging and testing purposes.
How do I open the adb shell on my Android tablet?
To open the adb shell on your Android tablet, you will need to first enable USB debugging in the Developer Options on your device. Then, connect your tablet to your computer via USB and open a terminal or command prompt window. Finally, type in the command "adb shell" to access the adb shell on your tablet.
What can I do with the adb shell command on my Android tablet?
The adb shell command on your Android tablet allows you to access various features and functions of your device, such as installing or uninstalling apps, accessing system files, and running various commands and scripts for debugging purposes. It also allows you to use your computer's keyboard to input commands and navigate your tablet's interface.
How do I exit the adb shell on my Android tablet?
To exit the adb shell on your Android tablet, you can simply type in the command "exit" and press enter. This will close the adb shell and return you to your computer's terminal or command prompt window.
Can I use the adb shell command on any Android tablet?
Yes, the adb shell command is available on all Android tablets. However, you will need to have USB debugging enabled and have the necessary drivers installed on your computer in order to use the adb shell on your specific device.
