Angle between magnetic field B and velocity of charge
In summary, to find the magnitude and direction of F for a charge moving through a magnetic field, we can use the equation F=qvBsinθ, where θ is the angle between the velocity and the magnetic field. In this problem, B is pointing out of the page and v is moving from left to right. Using the right hand rule, we can see that the angle between v and B is 90°, making sin(90)=1. Therefore, the magnitude of F is qvB and the direction is perpendicular to both v and B, pointing upwards.
ivanwho49
Find magnitude and direction of F of a charge moving through a magnetic field.
velocity: 5 m/s
charge: 2 C
B: 3 T (pointing out of the page when drawn)
(vector)F=qv x B
(magnitude)F=qvBsinθ
I know to use the equation for magnitude but I'm confused as to what the angle would be between v and B. Since the magnetic field is pointing out of the page, would the angle be 90°, making sin(90)=1?
Also, don't know what direction that would be. Since I don't know the direction of B, I'm not sure how to use the right hand rule to figure this out.
You do know the direction of B. It's out of the page.
Unfortunately, the problem does not define the direction of v so you can't solve it.
Sorry, forgot to mention that: the velocity moves straight from left to right.
OK, so place a sheet of paper on the table, draw an arrow from left to right = v, then hold a pencil at the back end of the arrow pointing straight up (B).
What is the angle between the arrow and the pencil?
I would suggest using the right hand rule to determine the direction of the force. Place your right hand so that your fingers point in the direction of the velocity and your thumb points in the direction of the magnetic field. The direction your palm faces is the direction of the force. In this case, the force would be perpendicular to both the velocity and the magnetic field, so the angle between them would indeed be 90°. Therefore, the magnitude of the force would be qvBsin(90) = 2 C * 5 m/s * 3 T * 1 = 30 N. The direction of the force would depend on the direction of the magnetic field, which is not specified in the problem. If the magnetic field is pointing towards the left, for example, then the force would be pointing downwards according to the right hand rule.
FAQ: Angle between magnetic field B and velocity of charge
What is the angle between the magnetic field B and the velocity of a charged particle?
The angle between the magnetic field B and the velocity of a charged particle is known as the magnetic angle. It is measured as the angle between the direction of the magnetic field and the direction of the velocity of the particle at a specific point in time.
Why is the angle between B and velocity important in understanding the motion of charged particles?
The angle between B and velocity is important because it determines the strength and direction of the Lorentz force acting on the charged particle. This force is responsible for the motion of charged particles in magnetic fields and plays a crucial role in many scientific phenomena.
How is the angle between B and velocity calculated?
The angle between B and velocity can be calculated using vector algebra, by taking the dot product of the magnetic field vector and the velocity vector. The resulting angle is then determined using trigonometric functions such as cosine or sine.
What happens to the motion of a charged particle if the angle between B and velocity is 0 degrees?
If the angle between B and velocity is 0 degrees, the Lorentz force acting on the charged particle will be perpendicular to its velocity. This results in a circular motion, with the particle continuously changing direction but maintaining a constant speed.
Can the angle between B and velocity change?
Yes, the angle between B and velocity can change if either the magnetic field or the velocity of the charged particle changes. This is because the Lorentz force acting on the particle is dependent on both the magnetic field and the velocity, and any changes in these parameters will affect the angle between them.
