Angle between proton velocity and B-field
The discussion centers on the relationship between the angle of proton velocity and the magnetic field (B-field). It clarifies that both angles involved in the problem are supplementary, meaning they add up to 180 degrees. Either angle can be used if only the magnitude of the cross product is needed. The participants confirm the correctness of using either angle in this context. The conversation emphasizes the simplicity of the solution while addressing potential confusion.
member 731016
Please see below
F = qV x B
For this problem,
The solution is,
However, this may seem like a silly question, but do we need both angles?
Many thanks!
The two angles are supplementary. Either one is correct if you only have the magnitude of the cross product.
Likes member 731016
Thank you @kuruman !
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
