What Is the Correct Angle Between Vectors a and c?
In summary, the correct angle between vectors a and c can be determined using the dot product formula, which relates the cosine of the angle to the magnitudes of the vectors and their dot product. By rearranging this formula, one can calculate the angle by taking the inverse cosine of the dot product divided by the product of the magnitudes of the vectors.
nafisanazlee
Let a = 2i + j - 2k, b = i + j and c be a vector such that |c-a| = 3, | (a x b) x c| = 3 and the angle between c and a x b is 30°. Then, a.c is equal to?
a.b = |a||b|cosθ
|a×b| = |a||b|sinθ
The solution to the question is attached herewith. I approached in the exact same way and got |c| = 2. Then I thought like this:
the angle between a and a×b is 90°, and the angle between c and a×b is 30° (given). So one of the possibilities is, the angle between a and c is 90-30=60° degree. |a| = 3, and a.c gives me 2.3.cos60° = 3, which is not the correct answer. My question is, am I wrong in some way? Or the question has some problem in it?
Can you provide us your detailed reasoning on why you think that the angle between a and c is 60 degrees?.
By the way you infer that it is 60 degrees it seems to me that you assume that the vectors a, axb and c are all belonging on the same plane but this is not the case. According to standard euclidean geometry two vectors always belong in the same plane, but three vectors dont always do that.
Likes PhDeezNutz, SammyS and nafisanazlee
There's a flaw in your logic. The cross product a×b defines a vector that is perpendicular to the plane in which a and b lie. The fact that c makes an angle of 30° doesn't necessarily mean that c makes an angle of 60° with either a or b, only that it makes this angle with the plane that a and b lie in.
Likes PhDeezNutz and nafisanazlee
got it, thanks!
Thank you! got it.
