Angle of Inclination Homework: Find θ at Ladder's Verge of Slipping
The discussion centers on calculating the angle of inclination (θ) of a ladder on the verge of slipping as a person climbs it. The ladder, measuring 5 meters in length, has a coefficient of friction of 0.28 between it and the ground. As the person reaches the mid-point of the ladder, the calculations involve analyzing forces and torques, with participants emphasizing the importance of using symbolic expressions rather than numerical values until the end. There is debate about the relevance of the angle of repose and how to accurately represent the torque equations. Ultimately, the calculated angle of inclination is around 82.032 degrees, but there is uncertainty regarding whether this angle is measured from the vertical or horizontal.
SpiraRoam
A ladder of length 5 m is resting against a SMOOTH wall, its point of contact being just below a first floor window. The bottom of the ladder rests on the ground and the coefficient of friction between the ladder and the ground is 0.28
A person of mass 78 kg climbs the ladder, which has a mass of 6 kg. The bottom of the ladder is at the point of slipping, outward from the wall, just as the person reaches the mid-point of the ladder’s length.
Determine the angle of inclination (θ) of the ladder, when the person is at the mid-point and the ladder is on the verge of slipping.
I'm not sure whether the angle of repose is relevant? θ=tan-1μ with μ being the coefficient of friction
w=mg and N (normal reaction) =mg
I was going to apply the method from exercise 13.1.3 at http://physique.merici.ca/mechanics/chap13mech.pdf
But is this relevant to to the angle at the verge of slipping? I can't see how the angle of repose is the answer - the question is 6 marks and that's too simple of a solution
Thanks
Please show your attempt at the solution including a free body diagram that applies to this problem. The angle of repose may or may or may not be relevant. Let's see what comes out of the calculation.
Forces: X Y Torque
Weight of ladder 0 -58.86N x 5m x sin(90°- Ɵ)
Weight of Person 0 -765.18N 765.18N x 5m x sin(90°-ϴ)
Normal force wall FN1 0 0 Nm
Normal force ground 0 FN2 0 Nm
Friction force ground -Ff 0 0 Nm
That was supposed to be a table ^, but I can't seem to paste it here.
I would then put the results into the mechanics equations:
ΣFx = FN1 - Ff = 0
ΣFy = -98N-245N + FN2 = 0
Στ = -294.93Nm x sin(90 - θ) - 3825.9Nm x sin(90 - θ) + FN1 x 5m x sin(θ)=0
= -294.93 Nm x cos(90) - 3825.9 Nm cos(90) + FN1 x 5m x sinθ
= 4120.83 Nm x cosθ = FN1 x 5m x sinθ
= 4120.83 / 5 = FN1 x tanθ
= 824.166 = Ff x tanθ
824.166N ≤ μFN2 x tanθ
824.166N ≤ 0.28 x FN2 x tanθ
824.166N ≤ 0.28 x 824.04 x tanθ
824.166N / 230.7312 ≤ tanθ
3.572 ≤ tanθ
tan-1(3.572) ≤ θ
θ = 74.36°
Thanks
SpiraRoam said:
θ = 74.36°
That's not the number I got. It's difficult for me to check your work with all those numbers thrown in, but I suspect your torque equation is incorrect. If you repost, please use a symbolic expression in the form tanθ = a function of the relevant quantities, i.e. mperson, mladder, length of ladder, μ and g.
Not sure where I'd find / derive such an expression, there's no hint of it in the course notes..we've only been given the ones I mentioned
The ladder is 5m long. How far along it is the mass centre? Likewise, reconsider the torque for the man.
As kuruman suggests, it is far better to keep everything symbolic. Create symbols for all the given data, like WL for the weight of the ladder, etc. Do not plug in numbers until the end. This has many advantages, both for you and for the reader. They should teach you this.
Right in the middle, so 2.5m along
Would the angle of repose be subtracted from the final angle? Or is it not relevant? I'm getting a final value of 82.032 degrees
So why is that not in your calculation of torque?
It is, I've just corrected it to get the final value of 82.032 degrees - thanks for the heads up =]
Ok.
But to make your work intelligible, please repost using W for the weight total (the two weights are at the same point, so no need to distinguish), L for length of ladder, F for the frictional force and μ for the coefficient. If handling two normal forces, distinguish with a subscript.
When you write a torque equation, you should state your chosen axis.
It asks for the inclination of the ladder. That suggests to me they want the angle to the vertical, but I could be wrong.
  • · Replies 20 ·
15K
