Angle relationships of a blazed diffraction grating
In summary, the person is trying to understand how a blazed diffraction grating works and came across a deduction they don't understand. They believe that you don't need to know much about optics to answer this question as it is more geometry related. They have the diagram below of a diffraction grating with all the relevant angles labeled. The blue zag is a zoom in of the diffraction grating surface. A beam (orange arrow on the left) is hitting a face on the surfaces and reflecting (orange arrow on the right) relative to normal of the face which is the dotted line between the arrows. The deduction made is that θi - θr = 2γ and I can't seem to deduce
NihalRi
134
I am trying to understand how a blazed diffraction grating works and came across a deduction I don't understand. I believe that you don't need to know much about optics to answer this question as it is more geometry related.
I have the diagram below of a diffraction grating with all the relevant angles labeled.
The blue zag is a zoom in of the diffraction grating surface. A beam (orange arrow on left) is hitting a face on the surfaces and reflecting (orange arrow on right) relative to normal of the face which is the dotted line between the arrows.
The deduction made is that θi - θr = 2γ and I can't seem to deduce this. I'll be happy to provide any additional information and any help will be appreciated.
Science news on Phys.org
## \theta_i-\gamma=\gamma-\theta_r ## for angle of incidence =angle of reflection (measured from the normal to the blaze). Simple algebra gives ## \theta_i+\theta_r=2 \gamma ##. The equation they have is in error, unless they assign an opposite sign to ## \theta_r ##. ## \\ ## (In some derivations, they do assign an opposite sign to ## \theta_r ##. The equation for constructive interference between adjacent slits or lines on a grating reads ## m \lambda=d (\sin{\theta_i}\pm \sin{\theta_r} ) ##, (this is the condition/location for a primary maximum in the diffraction pattern), where the sign that is used in the ## \pm ## depends upon the sign convention for how ## \theta_r ## is measured. When they put in this opposite sign, this makes ## \theta_i=\theta_r ## for ## m=0 ##, so that the equation reads ## m \lambda=d (\sin{\theta_i}-\sin{\theta_r} )##).
Likes NihalRi
Thank you, this makes perfect sense now!
Likes Charles Link
On another note, I'm likely to make this another thread but my aim is to uses the grating to combine two laser beams of different wavelengths. I want to do this in an energy efficient manner. Do you know any good resources I could use that explains the math of a blazed grating well?
Your idea sounds like something that could work. Meanwhile I don't have any good source at present that discusses blazed gratings. You would need to google the topic. ## \\ ## For a blazed grating, the peak occurs when incident angle equals angle of reflection off of the blaze, but there is a spread of angles that can get a similar intensity, basically as a result of the single slit diffraction pattern width that occurs, as a multiplying factor of the multi-slit or multi-line interference result from the grating. See also: https://www.physicsforums.com/threa...ratio-of-power-densities.956805/#post-6066788 along with the "link" in post 7 of that thread which I will repeat here: http://www.physics.louisville.edu/cldavis/phys299/notes/lo_msgratings.html
Likes NihalRi
These look really helpful I will have a look into them. I had been reading that the Littrow configuration you mentioned had high efficiency. However wouldn't the order with the most energy be reflected back on the incidence beam and due to the conservation of energy the other orders be less intense?
In general, (there are exceptions), the strongest portion of the emerging energy will not reflect back from where it originated. ## \\ ## I think you could even do what you are trying to do without a blazed grating. With an unblazed grating, the region with the highest energy will be such that the angle of incidence is approximately the angle of reflection. ## \\ ## You would simply take the two beams of interest and have them incident from reasonably close angles, and adjust the incident angles to get the primary maxima to coincide on the emerging beams. The emerging beams are most readily viewed by using a lens or paraboidal mirror to bring the beams to focus in the focal plane of the focusing optic. The beams will each focus to a point. The idea would be to get the focused points to coincide, by adjusting the incident angles. ## \\ ## Depending on the wavelengths that you have, you might have them be primary maxima of different orders ## m ##.
Likes NihalRi
One additional tip for you on this project: In general, a typical laser is not collimated=it is a slightly diverging source. e.g. For a commercial type HeNe, it emerges from a small aperture and the beam spreads slightly with distance. If you want high precision in the focusing in the focal plane, it can be helpful to use optics to collimate the beams you are using. Alternatively, you can have them be far enough from the diffraction grating that the beam fills the grating. It will still tend to focus with ## \frac{1}{f}=\frac{1}{b}+\frac{1}{m} ##, but with ## b ## quite large, the focus distance ## m \approx f ##.
Likes NihalRi
FAQ: Angle relationships of a blazed diffraction grating
1. What is a blazed diffraction grating?
A blazed diffraction grating is a type of optical element that consists of a series of parallel lines or grooves etched into a surface, separated by a fixed distance. These lines act as a series of parallel slits, causing light passing through them to diffract and produce a spectrum of colors.
2. How do you determine the angle relationships of a blazed diffraction grating?
The angle relationships of a blazed diffraction grating can be determined using the grating equation: nλ = d(sinθm - sinθi), where n is the order of diffraction, λ is the wavelength of light, d is the distance between grating lines, θm is the diffraction angle, and θi is the angle of incidence.
3. What is the significance of the blaze angle in a blazed diffraction grating?
The blaze angle is the angle at which the grooves of a diffraction grating are cut. This angle is important because it determines the direction in which the diffracted light is focused. A properly designed blaze angle can maximize the intensity of a specific wavelength of light in the diffraction pattern.
4. How does the number of grooves on a blazed diffraction grating affect the quality of the diffraction pattern?
The number of grooves on a blazed diffraction grating affects the resolution and intensity of the diffraction pattern. As the number of grooves increases, the resolution of the spectrum improves, allowing for more accurate measurement of the wavelengths of light. However, too many grooves can also cause overlapping of the diffracted light, reducing the intensity of the spectrum.
5. What are some real-world applications of blazed diffraction gratings?
Blazed diffraction gratings have a wide range of applications in various fields, including spectroscopy, telecommunications, and optical data storage. They are commonly used in spectrophotometers to analyze the composition of substances based on their absorption or emission spectra. In telecommunications, blazed diffraction gratings are used in fiber optic networks to separate and combine different wavelengths of light. They are also used in high-density optical data storage devices, such as Blu-ray discs, to store and retrieve large amounts of data.
