How Do You Calculate the Angular Acceleration of an Arm?
In summary, the problem involves a 1.20-kg ball being thrown by the action of the forearm, which has a mass of 3.7 kg and rotates about the elbow joint. The ball is accelerated uniformly from rest to 9.5m/s in 0.38s, and the forearm is assumed to rotate like a uniform rod about an axis at its end. Part A asks for the calculation of the angular acceleration of the arm, which can be obtained by using the equation "angular acceleration=Δω/Δt" and substituting the value for ω with v=rω, where r is the length of the arm. For part B, it is necessary to draw a free body diagram
tristanmagnum
44
Assume that a 1.20-kg ball is thrown solely by the action of the forearm, which rotates about the elbow joint under the action of the triceps muscle, the figure. The ball is accelerated uniformly from rest to 9.5m/s in 0.38s , at which point it is released. Assume that the forearm has a mass of 3.7 kg and rotates like a uniform rod about an axis at its end.
Part A: Calculate the angular acceleration of the arm.
Part B:Calculate the force required of the triceps muscle.
i believe angular acceleration=Δω/Δt
really lost on this problem physics is not my strong suit.
Well, for part A, you pretty much solved it already. Just plug in the 9.5m/s for Δω, and .38s for Δt. For part B, remember that F=ma. You calculuated the angular acceleration, and you are given mass, once again, just plug it all in.
Is there any diagram associated with your questions which may contain useful information? This question is not solvable without the length of arm.
if you arent solving for torque, why is the length of the arm necessary?
The unit for Δω is rad/s. 9.5m/s should be speed.
Torque never come to my mind when i mention the length of the arm.
since v=rω, it is important to have r in order to solve for ω.
For part A, you can start from the equation "angular acceleration=Δω/Δt". (Note the word angular, acceleration is different from angular acceleration)
By using v=rω, substitute into α =Δω/Δt and you will get the answer.
For part b, it is already answered by Periapsis, except that you should use acceleration instead of angular acceleration in your "F=ma".
so i substitute the equation for α in v=rω?
what would r be?
Originally, you have α=Δω/Δt. Now use ω=v/r to replace the ω in your original equation.
r will be the length of arm. What do you think is the length of arm, according to the diagram provided?
wouldn't it be 31?
or .o31 m?
it's neither of them. Since this has to do with unit conversion, I suggest you revise it from your textbook. You will find yourself solving problems with ease once you have strong command of the basics.
oh dang my bad it was .31!
Now you get it.:smile:
so now ill just plug in the acceleration i found and the mass
but which mass would i use?
F=ma says that an object with mass m will experience acceleration a under force F.
The acceleration you obtained belong to which object? Arm? Ball?
Which mass should you use then?
the mass of the arm? correct
add the two masses up.
Ops! Part B appeared to be more tricky than I initially thought. You can forget using F=ma to solve it.
May I know where you get this problem?
There are a few assumptions to be made in order to solve this problem. Still, it takes plenty of steps to get the final answer.
First, you must draw the free body diagram with the arm and the ball as the system. This will help you to picture how each components contribute to the τ (net torque) of the system.
With τ=Iα,where I is the moment of inertia, α is the angular acceleration, you will be able to get the value of τ, provided you know how to calculate I. (refer to your textbook on moment of inertia for uniform rod)
τ(tricep) - τ(arm) - τ(ball) = τ(net)
Using the above equation, you will be able to solve for τ(tricep) and in turn, F(tricep).
You will need this in your workout: τ=Fr where r is the distance from the pivot point to the point where force is applied.
How can you get the moment of inertia if you don't have the radius of the ball? 2/5mr^2
i guess, I = ∫ r2d(m) could work
Maybe there is no need to calculate moment of inertia. Use τ=Fr to calculate τ(net) will do. F can be obtained through F=ma and r can be obtained through finding the centre of mass of the system.
Anyways, it is up to the original question raiser to do the math.
You can treat the ball as a point mass, making its MI about the arm's axis easy. The Mi of the arm is obtained by treating it as a rod rotated about one end.
Unless there's more info in the diagram, there's not enough to determine the force from the triceps. All you can do is calculate the torque.
Related to How Do You Calculate the Angular Acceleration of an Arm?
What is angular acceleration of an arm?
Angular acceleration of an arm refers to the rate of change of angular velocity of an arm over time. It measures how fast the arm is rotating or changing its direction.
How is angular acceleration of an arm calculated?
Angular acceleration of an arm is calculated by dividing the change in angular velocity by the change in time. It can be expressed mathematically as angular acceleration (α) = (ω2 – ω1) / (t2 – t1), where ω is the angular velocity and t is the time.
What factors affect the angular acceleration of an arm?
The angular acceleration of an arm is affected by several factors, including the mass and length of the arm, the force applied, and the moment of inertia of the arm. These factors determine how quickly the arm can rotate or change its direction.
How does angular acceleration of an arm differ from linear acceleration?
Angular acceleration of an arm is a measure of how quickly the arm is rotating, while linear acceleration is a measure of how quickly the arm is moving in a straight line. Angular acceleration is measured in radians per second squared, while linear acceleration is measured in meters per second squared.
What are some real-life applications of angular acceleration of an arm?
The concept of angular acceleration of an arm is used in many fields, including robotics, biomechanics, and sports science. It is important for understanding the movement and control of robotic arms, analyzing the mechanics of human movement, and optimizing athletic performance in sports like baseball, golf, and tennis.
  • Biology and Medical
