Angular acceleration of plank hanging off edge with a weight
In summary, the angular acceleration of a plank hanging off the edge with a weight attached is determined by the torque produced by the weight acting at a distance from the pivot point (the edge of the plank). The relationship between torque, moment of inertia, and angular acceleration can be described using the equation τ = Iα, where τ is the torque, I is the moment of inertia of the plank, and α is the angular acceleration. Factors such as the mass of the weight, the length of the plank, and the distribution of mass affect the overall angular motion as the plank begins to rotate downward due to gravity.
pbnj
A heavy, 6m long uniform plank has a mass of 30 kg. It is positioned so that 4m is supported on the deck of a ship and 2m sticks out over the water. It is held in place only by its own weight. You have a mass of 70kg and walk the plank past the edge of the ship.
a) How far past the edge do you get before the plank starts to tip, in m?
b) If you go 10cm past the point determined above, what is the angular acceleration of the board in rad/s^2 ?
$$\tau_{net} = I\alpha$$
$$I = \sum_j m_j r_j^2$$
$$\tau = rF\sin\theta$$
Supposing L = 6m, m = 30kg, M = 70kg, h = 2m. Also set the origin at the leftmost edge of the plank.
Free body diagram description:
The center of mass of the plank is at ##\frac{L}{2}##, so considering it as a point mass, it feels the force of gravity ##F_m = mg##.
The person is at some point ##x##, and feels the force of gravity ##F_M = Mg##.
The pivot point is where the plank meets the edge of the ship, this is at ##L - h##.
The lever arm of the plank is the distance from the pivot point to the plank's center of mass, ##r_m = |L - h - \frac{L}{2}| = |\frac{L}{2} - h|##.
The lever arm of the person is ##r_M = x##.
As the person walks towards the rightmost point possible while not falling down, the normal force of the ship on the plank becomes localized at the pivot point.
For a), since the normal force is at the pivot point, its torque is 0.
The torque of the plank is ##\tau_m = r_m F_m##, positive since it would induce a counterclockwise rotation about the pivot.
The torque of the person is ##\tau_M = -r_M F_M##, negative since it would induce a clockwise rotation.
Hence ##\tau_m + \tau_M = 0## implies ##r_M = \frac{\tau_m}{F_M} \approx 0.43m##.
This is apparently correct.
For b), I define a new lever arm and torque to take into account the extra 10cm; ##r_M' = r_M + 0.1m## and ##\tau_M' = -r_M'F_M##.
Using the formula for moment of inertia, I calculate ##I = mr_m^2 + M(r_M')^2##, and the net torque is ##\tau_{net} = \tau_m + \tau_M'##.
So the angular acceleration should be ##\alpha = \frac{\tau_{net}}{I} \approx -1.38##, in units of radians/s^2. However, this is apparently wrong.
What is the moment of inertia of a uniform plank about its centre?
(I would choose the pivot point as origin.)
I figure since we're only given the length and mass of the plank, it should be ##\frac{1}{12}mL^2##. Then I should use the parallel-axis theorem to get the moment of inertia of the plank about the pivot, which is ##I_m = \frac{1}{12}mL^2 + mr_m^2##. So moment of inertia of the plank and human should be ##I = I_m + I_M## where ##I_M = M(r_M')^2##, then using ##\alpha = \frac{\tau_{net}}{I}## I get a final answer of -0.49 rad/s^2, which is apparently still wrong.
Your method looks ok now, but I do get different second significant digit. Please post your detailed working.
I've been using lean4 as my calculator, here's my source code:
Code:
def g := 9.81
def m := 30.0
def M := 70.0
def L := 6.0
def h := 2.0
def rm := (0.5*L - h).abs
def Fm := m*g
def FM := M*g
def τm := rm*Fm
def rM := τm/FM
def τM := -rM*FM
#eval rM
def rM' := rM + 0.1
def τM' := -rM'*FM
def τnet := τM' + τm
def Im := (1/12)*m*L^2 + m*rm^2
def IM := M*(rM')^2
def I := Im + IM
def α := τnet / I
#eval α // -0.492057
and it can be pasted here, then place the cursor on the last line to see the answer I got. I double-checked that the numeric literals are getting inferred as Floats, so there's no weird integer division going on.
Code:
def g := 9.81
def m := 30.0
def M := 70.0
def L := 6.0
def h := 2.0
def Fm := m*g
def FM := M*g
def τm := rm*Fm
def rM := τm/FM
def τM := -rM*FM
#eval rM
def rM' := rM + 0.1
def τM' := -rM'*FM
def IM := M*(rM')^2
def I := Im + IM
def α := τnet / I
Apologies, it was my error. I now get the same as you.
A possibility is that you should answer -.5 on the basis that some given data only have one significant figure, but that seems unlikely.
Why would we include the mass moment of inertia of the human? The human doesn’t rotate with the plank. They are an external force on the plank, and it seems likely (to me) they just fall straight down when the plank flips?
The person's weight causes the plank to rotate, therefore, at least to begin with, they remain in contact. Whether the person is merely standing on the plank or is glued to it cannot make a difference at that stage.
If you prefer, you can treat them separately, but you have to consider that since the person has a downward acceleration of ##\alpha x## the force exerted on the plank is ##M(g-x\alpha)##. As a torque, that is ##Mgx-Mx^2\alpha##. This produces the same equation as before.
Likes SammyS and erobz
FAQ: Angular acceleration of plank hanging off edge with a weight
What is angular acceleration?
Angular acceleration is the rate of change of angular velocity over time. It describes how quickly an object is rotating or spinning and is usually measured in radians per second squared (rad/s²).
How do you calculate the angular acceleration of a plank hanging off the edge with a weight?
To calculate the angular acceleration of a plank hanging off the edge with a weight, you need to consider the torque applied by the weight and the moment of inertia of the plank. The angular acceleration (α) can be found using the formula: α = τ / I, where τ is the torque and I is the moment of inertia.
What factors affect the angular acceleration of the plank?
The angular acceleration of the plank is affected by several factors, including the mass and position of the weight, the length of the plank, the point where the plank is pivoted, and the distribution of the plank's own mass. The torque generated by the weight and the moment of inertia of the plank are key determinants.
How does the position of the weight on the plank influence angular acceleration?
The position of the weight on the plank significantly influences the angular acceleration. If the weight is placed further from the pivot point, it creates a larger torque due to the increased lever arm distance, resulting in greater angular acceleration. Conversely, placing the weight closer to the pivot reduces the torque and thus the angular acceleration.
What is the moment of inertia and how is it calculated for the plank?
The moment of inertia is a measure of an object's resistance to changes in its rotational motion. For a uniform plank of length L and mass M pivoted at one end, the moment of inertia is calculated using the formula I = (1/3)ML². If the plank has a different mass distribution or is pivoted at a different point, the moment of inertia will need to be calculated accordingly.
