MHB Angular and Linear Speed....Part 1
  • Thread starter Thread starter mathdad
    Angular Linear
The discussion focuses on calculating angular and linear speeds based on a wheel's rotation rate and radius. For Part A, the correct angular speed is derived as 50 pi/3 radians/sec, which requires converting revolutions per minute to radians per second by dividing by 60. In Part B, the linear speed of a point on the circumference is calculated as 750 pi cm/sec, while the speed for a point halfway to the center in Part C is 375 pi cm/sec. The confusion arises from the need to convert units properly and apply the correct formulas. Overall, the calculations emphasize the importance of unit conversion in achieving accurate results.
mathdad
You are given the rate of rotation of a wheel as well as its radius. For A-C, determine the following:
A. The angular speed, in units of radians/sec.
B. The linear speed, in units of cm/sec, of a point on the circumference of the wheel.
C. The linear speed, in cm/sec, of a point halfway between the center of the wheel and the circumference.
I will now post my effort.
Given: 500 rpm; r = 45 cm
Part A
The angular speed formula is w = θ/t.
I know that 1 revolution = 2pi radians.
I need θ.
θ = 500 (2pi radians)
θ = 1,000 pi radians.
w = 1,000 pi radians/sec
Book's answer is [50 pi/3] radians/sec. Something tells me that I needed to convert seconds to minutes. Yes?
Part B
I used the arc length formula, s = θr, as step 1.
s = (1,000 pi radians)(45 cm)
s = 45,000 pi cm = d
The letter d represents the distance in time t in the linear speed formula v = d/t.
v = 45,000 pi cm/sec is my answer.
Book's answer for Part B is 750 pi cm/sec.
Again, I am thinking that the units of conversation needed to be changed. Yes?
Part C
s = θr
s = (1,000 pi radians)(22.5 cm)
The decimal 22.5 came from dividing the radius in half in terms of the instructions for Part C above.
s = 22,500 pi cm = d
v = d/t
v = 22,500 pi cm/sec
Book's answer is 375 pi cm/sec.
Mathematics news on Phys.org
A. $$\omega=\frac{\theta}{t}$$
$$\omega=\frac{500\text{ rev}}{1\text{ min}}\cdot\frac{2\pi\text{ rad}}{1\text{ rev}}\cdot\frac{1\text{ min}}{60\text{ s}}=\frac{50\pi}{3}\,\frac{\text{rad}}{\text{s}}$$
B. $$v=\omega r$$
$$v=\left(\frac{50\pi}{3}\,\frac{\text{rad}}{\text{s}}\right)\left(45\text{ cm}\right)=750\pi\frac{\text{cm}}{\text{s}}$$
C. $$v=\omega r$$
$$v=\left(\frac{50\pi}{3}\,\frac{\text{rad}}{\text{s}}\right)\left(\frac{45}{2}\text{ cm}\right)=375\pi\frac{\text{cm}}{\text{s}}$$
B. $$v=\omega r$$
C. $$v=\omega r$$
I follow everything you did here except for Part A.
Where did 50 pi/3 come from? Don't we multiply 500 rpm by 2 pi radians? Is 500 rpm • 2 pi radians not equal to 1,000 pi radians?
Yes, but we also must divide by 60, and then reduce the fraction. :)
Oh boy! I better go back to 5th grade math.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
14K
