Angular momentum and spin unit
In summary: They correspond to the spin state ##\frac {\sqrt 3} 2 \hbar##.We cannot measure ##\vec{S}##, but we can measure ##|\vec{S}|^2##, the square of its magnitude, and then take the square root to get the magnitude. There's an easy visualization: imagine the set of vectors with their base at the center of the Earth and their tip on the Arctic circle. All of these vectors have the same squared magnitude and the same ##z## component, but the other two components and the overall direction are not determined. They correspond to the spin state ##\frac {\sqrt 3} 2 \hbar##.In summary, spin
Edge5
I know that spin is a type of intrinsic angular momentum.
For electron spin is (1/2)ħ . But unit of (1/2)ħ is J.s, which is not the unit of angular momentum. Can you please explain this discrepancy?
Actually, that is the unit of angular momentum, ##J\cdot s =\frac{kg\cdot m^2}{s}##. It's also the unit of action in classical mechanics.
Likes Edge5
... and in quantum mechanics.
Likes Edge5
That is not correct. The spin quantum number is ##s=1/2##, which means that the spin angular momentum is ##\sqrt{s(s+1)} \hbar = \frac{\sqrt{3}}{2} \hbar##.
Likes Edge5
More explicitly, angular momentum is a vector quantity. An electron's spin angular momentum has magnitude ##\frac {\sqrt 3} 2 \hbar## as DrClaude noted. Its component in any direction is ##\pm \frac 1 2 \hbar##.
Likes Edge5
Do you mean the net magnitude of total spin vector is ##\frac {\sqrt 3} 2 \hbar## ? Do we consider spin as a 3-D vector?
I mean if spin is a vector like A(x hat) + B(y hat) + C(z hat).
Is ##\frac {\sqrt 3} 2 \hbar## = sqrt( A^2 +B^2 +C^2)
Classically, spin angular momentum is a vector whose direction is along the object's axis of rotation:
http://hyperphysics.phy-astr.gsu.edu/hbase/amom.html#am
In QM, there's no definite axis of rotation, but we can still say that spin angular momentum has a definite magnitude (##\frac {\sqrt 3} 2 \hbar## for an electron), and certain allowable values for its component along any measurement axis (##\pm \frac 1 2 \hbar## for an electron) which we traditionally call the "z-direction" even though it could just as well be the x-direction or the y-direction or any other direction.
http://hyperphysics.phy-astr.gsu.edu/hbase/spin.html
So does that mean we can't measure ##\frac {\sqrt 3} 2 \hbar## (since it involves all direction of vectors) but we can measure it only in one direction which gives us a result of ##\pm \frac 1 2 \hbar## ?
Related to Angular momentum and spin unit
1. What is angular momentum?
Angular momentum is a physical quantity that measures the rotational motion of an object. It is calculated by multiplying the moment of inertia of the object by its angular velocity.
2. What is the difference between angular momentum and linear momentum?
Angular momentum is a measure of rotational motion, while linear momentum is a measure of straight-line motion. Angular momentum takes into account both the mass and the distribution of that mass around a central axis, while linear momentum only considers the mass and velocity of an object in a straight line.
3. What is spin in quantum mechanics?
In quantum mechanics, spin is a property of particles that describes their intrinsic angular momentum. It is a quantum mechanical version of angular momentum that is not related to the physical rotation of an object, but rather to its internal properties.
4. How is angular momentum conserved?
Angular momentum is conserved in a closed system, meaning that it cannot be created or destroyed. It can only be transferred between different forms, such as from rotational motion to linear motion or vice versa.
5. What are some real-life examples of angular momentum?
Some common examples of angular momentum in everyday life include a spinning top, a rotating ceiling fan, and a spinning figure skater. The Earth and other planets also have angular momentum as they rotate around their own axes and orbit the sun.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
