Markus Kahn
- 112
- 14
Consider a 2-particle system where the two particles have angular momentum operators ##\vec{L}_1## and ##\vec{L}_2## respectively. The Hamiltonian is given by
$$H = \mu\vec{B}\cdot (\vec{L}_1+\vec{L}_2)+\gamma \vec{L}_1\cdot \vec{L}_2.$$
Determine explicitly the eigenvalues and eigenvectors of ##H## when the spins are ##l_1=l_2=1##.
All relevant Clebsch-Gordan coefficients are given in the form ##\langle 1,1, m_1,m_2 \vert 1,1, j,m \rangle \equiv \langle m_1,m_2 \vert j,m\rangle##.
We know that any state vector in the Hilbert-space is of the form ##\vert 1,1, m_1,m_2 \rangle = \vert1,m_1\rangle \otimes \vert 1,m_2\rangle##. Since the Hilbert space is a tensor product we can rewrite it as a direct sum of irreducible representations according to the Clebsch-Gordan-series and find
$$\vert j,m \rangle \equiv\vert 1,1, j,m \rangle = \sum_{\substack{m_1,m_2\\ m=m_1+m_2}} \langle 1,1,m_1,m_2\vert 1,1, j,m\rangle \vert 1,1, m_1,m_2\rangle\equiv \sum_{\substack{m_1,m_2\\ m=m_1+m_2}} \langle m_1,m_2\vert j,m\rangle \vert m_1,m_2\rangle .$$
Now I tried to figure out how ##H## acts on ##\vert m_1, m_2\rangle##. My first problem is that I don't know how ##\vec{L}_1, \vec{L}_2## act on the state vector.. To solve this I would need to assume that ##\vec{B}=B_z \vec{e}_z## and therefore get
$$\vec{B}(\vec{L}_1+\vec{L}_2)\vert m_1,m_2\rangle = B_z (L_1^z+L_2^z)\vert m_1,m_2\rangle = B_z(m_1+m_2)\vert m_1,m_2\rangle .$$
Is this a reasonable assumption or can one solve this without any assumptions for the magnetic field?
Now we still have the second part of the Hamiltonian left. My idea here was: ##L^2 \equiv (\vec{L}_1+\vec{L}_2)^2 = L_1^2+L_2^2+2L_1L_2 ## and therefore ##L_1L_2 = \frac{1}{2} (L^2-L_1^2-L_2^2)##. Now I only need to figure out how ##L^2## acts on ##\vert m_1,m_2\rangle##. Sadly, I can't really figure that part out...
And my last problem is: even if I would figure out how ##L^2## acts on the state, I have a hard time making the last steps to the original goal of finding all eigenvalues and -vectors explicitly.EDIT: I think I'm able to answer my first question:
Since we can chose the coordinate system in which we work, we can always chose on in which the magnetic field points in the ##z##-direction. The only assumption would then be that the magnetic field is constant...
