NATURE.M
- 301
1. Homework Statement [/b]
Consider a thin rod of mass m[itex]_{r}[/itex] and length L hanging from a pivot at its upper end. A ball of clay of mass m[itex]_{c}[/itex] and of horizontal velocity v[itex]_{0}[/itex] strikes the lower end of the rod at a right angle and sticks, causing the rod + ball to rotate. What is the angular velocity of the rod + ball immediately after the collision? (The moment of inertia of the rod about its CENTER OF MASS is ML^2/12. You can treat the clay ball as a particle).
Now the solution handout indicates L[itex]_{i}[/itex] = L[itex]_{f}[/itex], which I understand.
But then it indicates L[itex]_{i}[/itex] = I[itex]_{c}[/itex]ω[itex]_{c}[/itex][itex]^{2}[/itex], where I[itex]_{c}[/itex] is the moment of inertia of the ball. Now I don't understand why the ball traveling horizontally has angular momentum, unless it represents the angular momentum of the system the instant the ball makes contact with the rod. Otherwise, the angular momentum of the system should be 0 initially. Any clarification is appreciated.
