Prashan Shan
- 31
Will the angular momentum of a half filled waterbottle increase? or decrease? or remain the same?
when compared to the angular momentum of the bottle at instant when it started spinning.nasu said:As compared to what?
about its center.nasu said:Spinning around what axis?
Angular momentum is a measure of the rotational motion of an object, calculated by multiplying the moment of inertia by the angular velocity.
The angular momentum of a half filled waterbottle is determined by its shape, mass distribution, and rate of rotation.
The water level affects the moment of inertia, which is a key component in the calculation of angular momentum. A higher water level will result in a higher moment of inertia and therefore a higher angular momentum.
Yes, angular momentum can change if there is a change in the moment of inertia, mass distribution, or angular velocity of the object.
Angular momentum is conserved in a half filled waterbottle as long as there are no external torques acting on the bottle. This means that the moment of inertia and angular velocity will remain constant, resulting in a constant angular momentum.
