Wheelwalker
- 43
- 1
Two concentric spherical shells carry uniformly distributed charges +Q (at radius a) and -Q (at radius b>a). They are immersed in a uniform magnetic field [itex]\vec{B}=B_0\hat{z}[/itex].
(a) Find the angular momentum of the fields (with respect to the center).
(b) Now the magnetic field is gradually turned off. Find the torque on each sphere, and the resulting angular momentum of the system.
[itex]\vec{g}=\epsilon_0 \vec{E}\times\vec{B}[/itex]
[itex]\vec{l}=\vec{r}\times\vec{g}[/itex]
[itex]\nabla\times\vec{E}=-\frac{\delta \vec{B}}{\delta t}[/itex]
I calculated an initial value for the angular momentum carried by the fields of [itex]\vec{L}=\frac{QB_0(b^2-a^2)}{3}\hat{z}[/itex]. This seems to make sense. The final angular momentum should be in the z hat direction as well, since the spheres will be spinning about the z axis.
I am stuck trying to find the electric field induced by the changing magnetic field. From Faraday's law, the electric field should be swirling around the z-axis, implying it should be in the phi hat direction. The field will exert a force on each sphere since they carry a charge and will send them spinning in opposite directions. This makes sense considering my initial angular momentum expression. But what is the easiest way to find the induced electric field? I attempted to use Faraday's law in integral form but I am not sure what Amperian loop to use. For cylindrical symmetry, I would use a simple circle and calculate the path integral of the electric field and the change in magnetic flux through that loop, then write my electric field in terms of B. I'm not so sure I can do the same thing with spherical symmetry.
