Angular Momentum of Earth Decreasing
In summary, the conversation is discussing whether it is true that the Earth's angular momentum is decreasing, causing it to slow down in its orbit around the Sun. It is mentioned that the Earth may be "several months" behind where it should be, but this is dependent on the time frame being discussed. It is also noted that the main reason for the Earth's decreasing momentum is due to dust falling into the atmosphere during its orbit. The exact rate of this decrease is not recalled.
Tax Tom
Does anyone know for sure if it's true that the angular momentum of the Earth has been decreasing, and that therefore the Earth is slowing down in it's orbit around the Sun, and is currently several "months" behind where it should be, in orbit?
I don't know how you could say the Earth is "several months behind where it should be" because that would depend on the time frame you are speaking of.
Otherwise yes, the Earth is slowly slowing down. Most of the reason, as I understand it, is dust falling into the Earth's atmosphere as the Earth goes around in it's orbit. I don't recall the rate, but it is fairly small.
-Dan
Related to Angular Momentum of Earth Decreasing
1. What is angular momentum?
Angular momentum is a physical quantity that measures the amount of rotation of a system around an axis. In the case of Earth, it refers to the rotation of the planet around its own axis.
2. Why is the angular momentum of Earth decreasing?
The angular momentum of Earth is decreasing due to the presence of external forces, such as the gravitational pull of the Moon and other celestial bodies, and the transfer of energy between the Earth's rotation and its orbit around the Sun.
3. How does the decrease in angular momentum affect Earth?
The decrease in angular momentum of Earth leads to a gradual slowing down of the planet's rotation. This results in longer days and shorter nights, and changes in the Earth's climate and weather patterns.
4. Is the decrease in angular momentum of Earth a cause for concern?
While the decrease in angular momentum of Earth is a natural process, it is not a cause for immediate concern. The changes in Earth's rotation and climate occur over long periods of time and are not significant enough to have a major impact on our daily lives.
5. Can the decrease in angular momentum be reversed?
The decrease in angular momentum of Earth cannot be reversed, as it is a result of natural processes. However, it can be affected by human activities, such as the construction of large dams or extraction of natural resources, which can alter the distribution of mass on Earth and affect its rotation.
