Vagabond7
- 50
- 11
A 1.9kg , 20 cm-diameter turntable rotates at 150rpm on frictionless bearings. Two 480g blocks fall from above, hit the turntable simultaneously at opposite ends of a diameter, and stick.
what is the objects angular velocity in rpm right after this event?
L=Iω where L is angular momentum, I is the moment of inertia and ω is the angular velocity
moment of inertia for a disk rotating about it's center 1/2*m*r^2
Ok, so it seems like a simple conservation problem, so I tried to solve it like one.
I final*ω final = I initial * ω initial
ergo
ω final = (I initial * ω initial)/ I final
convert 150 rpm in rad/s, (150/60)*2[itex]\pi[/itex] =15.71
since the formula for the moment of inertia "I" for a disk rotating about the center is 1/2*m*r^2
I just plug in the values
(.5*1.9kg*.1^2m*15.71 rad/s)/ (.5*(1.9+.96kg)*.1^2m) = 10.44 rad/s
converting back to rpm (10.44/ 2[itex]\pi[/itex] )*60 = 99.66 rpm rounded to 100 rpm.
But this solution is incorrect. What have I done wrong?
