A Angular momentum uncertainty principle and the particle on a ring
physical_chemist
TL;DR Summary
How can I think about the uncertainty principle for angular momentum components and the particle on a ring problem, since L and Lz are parallel in this case?
By considering a particle on a ring, the eigenfunctions of ##H## are also eigenfunctions of ##L_\text{z}##:
$$\psi(\phi) = \frac{1}{\sqrt{2\pi}}e^{im\phi}$$
with ##m = 0,\pm 1,\pm 2,\cdots##. In polar coordinates, the corresponding operators are
$$H = -\frac{\hbar^{2}}{2I}\frac{d^{2}}{d\phi^{2}}$$ $$L_\text{z} = -i\hbar\frac{\partial}{\partial \phi}$$
The Robertson version of uncertainty principle, valid in a statistical sense, tell us
$$\Delta L_{x}\Delta L_\text{y} \geq \frac{1}{2}\left | \int \psi^{*}[L_{x},L_{y}]\psi d\tau\right | $$ where usually ##[L_{x},L_{y}] = i\hbar L_{z}##. The operators for ##L_{x}## and ##L_{y}## are
$$L_{x} = i\hbar \left ( sin(\phi)\frac{\partial}{\partial\theta} + cot(\theta)sin(\phi)\frac{\partial}{\partial\phi}\right )$$
$$L_{y} = -i\hbar \left ( cos(\phi)\frac{\partial}{\partial\theta} - cot(\theta)sin(\phi)\frac{\partial}{\partial\phi}\right )$$
Since the ring plane is located on xy plane, i.e ##\theta = \pi/2##, we obtain
$$L_{x}\psi = L_{y}\psi = 0$$
This make sense, since the particle is rotating around z-axis. Then, ##[L_{x},L_{y}]\psi = 0##? Thus, in this specific case, doesn't the relation ##[L_{x},L_{y}] = i\hbar L_{z}## hold? The interpretation of uncertainty principle is valid for a complete set of eigenfunctions of two operators, but can exist some eigenfunctions of ##L_{z}## which are eigenfunctions of ##L_{x}## and ##L_{y}## (I only know the ##Y_{0}^{0}## case until now). Does it means that ##[L_{x},L_{y}] = i\hbar L_{z}## should be use with care? Why? Is it valid only when ##[L_{x},L_{y}]\psi \neq 0## ? Even expanding the ##L_{z}## eigenfunctions in spherical harmonic, I can't obtain a satisfactory answer. Angular momentum is a vector quantity. Could you help me?
If the particle is confined to a ring in the ##x y## plane, what physical meaning do the operators ##L_x## and ##L_y## have? Nothing can rotate about the ##x## or ##y## axis.
@PeterDonis, classically, when a particle is rotating about z-axis, the x,y components of angular momentum are zero, since L is a vector quantity and there is no rotation around such axes. But, in Quantum mechanics, there is an uncertainty relation which cannot allow this in principle (except when we have ##Y_{0}^{0}##). But, in the case above, the uncertainty relations seems to be in contradition, no?
In three dimensions, yes. But you have constrained the problem by confining the particle to a ring in the ##xy## plane. That means the problem is no longer three dimensional and what you are calling "the x,y components of angular momentum" are no longer even physically meaningful, since you have made it physically impossible for anything to rotate except in the ##xy## plane. Or, to put it another way, in two spatial dimensions, which is what you've confined this problem to, there is only one angular momentum component, the one you are calling ##L_z##.
But, in Quantum mechanics, there is an uncertainty relation which cannot allow this in principle (except when we have ##Y_{0}^{0}##). But, n the case above, the uncertainty relations seems to be in contradition, no?
No, because everything I said above about the problem being confined to two spatial dimensions is still true when we pass over from classical physics to quantum mechanics. There is still only one angular momentum component. It's now an operator instead of a number, but it's still just one operator, so the question of uncertainty relations for angular momentum operators doesn't even arise.
Likes Vanadium 50
Also in classical view, when a particle is rotating about z-axis, the x,y components of angular momentum are not zero. They are zero in the specific case which the ring is in the xy-plane, otherwise the angular momentum ##L## is rotating with the particle.
Classically, if the ring is not in the X-Y plane then the particle's rotation is not about the Z-axis. Assuming constant ##\left|\vec v\right|## and that the center of the ring is at the origin, ##\vec L## is constant (and perpendicular to the ring's plane).
Likes hokhani and weirdoguy
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
